Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 03:42 PM
animal70X7 animal70X7 is offline
animal70X7 is starting off with a positive reputation.
V10 is dieing, where do I go from here?
Long story short, I replaced the oil pump and cooler and the timing chain gears, chains and tensioner to "fix" (fix lasted 3 days) an oil pressure prob and am now experiencing low end noises preceded by loss of oil pressure, which has since come back to normal levels. 2 mechanics and a Ford Mech tell me it's probably spun bearings and I am better off replacing the motor. They claim that the labor alone for the job is almost as much as the motor. New Jasper cost roughly $3500. The most recommended rebuild guy in my area wants $4K and says that he knows of no performance upgrades internally. I have been somewhat underwhelmed with the pulling (or lack thereof) power. I pull a 7000# TT. 3V V10's don't seem to be an option and diesel swap seems to be a $10K endeavour. Sure could use some advice from someone familiar with the process by either doing this or paying to have it done. I would just like it to me reliable and tow my TT well.
  #2 (permalink)
Old 06-29-2009, 05:28 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life is gaining momentum as a positive member of FTE. Fordfanatic4life is gaining momentum as a positive member of FTE.
send a PM to FTEpartsguy..
he should be able to get u a price on a actual Ford replacement engine.
not sure what it will cost but its a option worth looking into...
was gunna suggest maybe it was just the oil pressure sending unit if u seeing 0 pressure, but bottom end noises cant be good..
i had a oil sending unit failure in my 2000 F150 5.4, super cheap repair. but then my motor wasnt maknig noise, just showing no pressure intermitentaly.
__________________
2003 F250 4x4 CC V10 4" Procomp, all white beauty
"list of previous owned Fords much to long to list here.."
  #3 (permalink)
Old 06-30-2009, 09:13 AM
brand new Melling pump.
  #4 (permalink)
Old 06-30-2009, 11:59 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
What year is the truck, and what gears do you have?
If the engine was good, I'd say get with Mike at 5-star tuning (the sponsor of this forum) and get his 87 octane custom towing tune. I tried it, and it is obvious the shifting alone would make a huge difference, but even the tune itself makes a noticable amount more low-end-torque than the stock tune.
As for the lack of oil pressure, doesn't sound good on the bottom end. I would consider either a used motor, or getting a Ford-rebuild from Ed - who used to be FTE/PARTS-GUY but not sure about that anymore.
If it were me, I'd pull the engine myself and rebuild the bottom end, but that's a lot of work and scary for someone who hasn't done stuff like that before.
If you're capable of pulling the engine yourself, that would save you a lot of labor $'s. It's not hard to pull it out the front, just remove as much of the front clip as you can, radiator, support, grill, etc, remove the throttle body (and the intake) and attach the boom of the engine hoist as close to the motor as possible before pulling it.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #5 (permalink)
Old 06-30-2009, 12:58 PM
2000 with 3.73's. 113000 miles
I have the SCT from Mike.
I just hate to be spending this much money and not be getting a bunch more power when it's done.
I don't have the know how to do this without having to pay someone double to fix what I mess up. Every mechanic I have spoken to over the last couple days (whether Ford or Chevy) advises me to either rebuild completely or replace. Apparently because the bearing job on this is about a 25+ hr job.
FTE's website says that they are not taking any more orders. I thought maybe they were going out of business or something.
  #6 (permalink)
Old 06-30-2009, 01:03 PM
Krewat's Avatar
FTE? or FTE/PARTS-GUY? Ed left whatever dealer he was at, and is working on getting to a new home, I believe. He can still get parts, though.
The 3.73's are killing you for towing ability. 4.30's would work much better. But that's a moot point right now.
With the cost of the new engine, and installation, maybe looking at another truck might be an option.
If it were me, I'd pull the pan, and a few main and rod bearings and see what they look like.
__________________
  #7 (permalink)
Old 07-04-2009, 02:43 PM
m350 m350 is offline
m350 is starting off with a positive reputation.
I just did see a V-10 engine for sale Ebay,,,was like $410 bucks for a complete motor,,,ya I know,,,where is it,,,,my point is,,,call some junk yards, check craigs list,,etc should be able to find one for sale for around $500 in running condition,,,call a buddy or 2 that has a bit of knowledge with engines,,,buy the Beer and do it up.
I would suggest changing and torqng the spark plugs, check and or replace all exhaust manifold studs while the engine is out,,much easier,,,Good Luck !
__________________
06' F-350 XLT SC, S-Bed, 6.0, Auto, man-hubs
04' Explorer NBX, 4.6, auto, 3:73 LS
68' Torino, 289, 4 gear
  #8 (permalink)
Old 07-05-2009, 05:00 AM
MXZX1100cc MXZX1100cc is offline
MXZX1100cc is starting off with a positive reputation.
Go to carparts.com they have all you need!
__________________
99 V10 F-250 ex. cab short bed 4X4 4.30 gears
6.5 Pro Comp Lift
315x75-16 Dick Cepeck Mud Country
16x10 Dick Cepeck DC1 Black Rims
5100 Series Bilstein Shocks
  #9 (permalink)
Old 07-05-2009, 09:12 AM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
Heres the new site.
http://www.trademotion.com/partlocat...?siteid=214072
  #10 (permalink)
Old 07-05-2009, 09:29 AM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
I have 3.73s in mine and it pull great, 30 mph and over.
You put 18K behind it and it is a turd starting on a hill up to about 35.
after that it will run with traffic at 1/4 to 1/2 throttle.
You should put a used motor in, swap the gears to 4.30s.
How many miles, and what trany?
__________________
my V10 will out pull your PSD any day of the week.
Quote:
Originally Posted by Jmeyer1990
... but i kept losing service in Victoria's Sectret, so I gave up.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
  #11 (permalink)
Old 07-06-2009, 08:50 AM
I decided to put a Ford reman in. Same price as a Jasper and I can get it warranteed any where in the country for the next 3 years. I have been told to swap out the oil pan for a baffled one. Any one know where to find one of these? Also, I am considering headers. Seams like if I am ever going to do them, now is the time. Anyone actually put headers on theirs? What did you use and why?
  #12 (permalink)
Old 07-06-2009, 11:46 AM
jrandol jrandol is online now
jrandol is starting off with a positive reputation.
Quote:
Darn! Wish I saw this sooner. I'd sell you my V10 for that kind of money so I could do a Diesel swap (Cummins)
  #13 (permalink)
Old 07-06-2009, 12:51 PM
Mmaxed Mmaxed is offline
Mmaxed is starting off with a positive reputation.
You must run with slow traffic.
__________________
2008 F-250 Lariat, CC, LB, V10, 4.30s
  #14 (permalink)
Old 07-06-2009, 07:16 PM
bill11012's Avatar
Why?
your 3V v10 that slow?
__________________
  #15 (permalink)
Old 07-07-2009, 01:24 PM
Why?
No it runs pretty decent. Anyway you slice it, it's not a diesel when it comes to a heavy load and it can't be. I love the truck, and the V10 isn't a bad motor don't get me wrong. When this motor craps out I'll definetely do the Cummins conversion.
Tags
04 , 430 , 68 , bearing , cooler , cost , explorer , f250 , ford , gears , oil , rebuild , rebuilt , repair , replacing , spun , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
