Motor is in and headers installed. Mechanic told me that the headers were an easy install that if he took them apart he could reinstall them in 15 minutes. They fit without any mods. They look good and no more restrictive Y pipe. No real noticeable difference in sound. I am not supposed to take the motor up above 2500rpm for the first 500 miles, so I really don't know the difference in performance yet. I will post pics as soon as the mech sends them to me. One ? though, if anyone knows. The old motor called for 5W30 and the new one 5W20 does this seem right?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see.
Just that I know one guy who used that stuff. The oil was perfectly stable up until his Ford I6 300 spun a main bearing, and his other engine, a 351W lost oil pressure and recovered (it had over 150K miles on it at the time, so it was very loose which probably saved it).
If you're using a good oil, you don't need to "stabilize" it.
__________________
at about 60k my v10 had a clatter to it, so i put in lucus.
20 seconds of running and it went away.
I have used it ever since in every thing i own.
it is slicker than oil, cushions and parts better and makes them run quieter.
I also use the atf additive, gear lube additive and PS fluid additive.
on high mile auto trans and PS pumps, it makes a difference you can tell from driving it before and after. in diffs. and manual trans, the difference is there, but much less so.
the thing is 20%. lots of people take the " more is better "approach.
I ashure you the V10 was tested in how weather with 5w-20 and 5w-30 and they found it works fine. Lucas stabilizer is best suited for lawnmowers or vehicles that have oil control problems.
Hey, more power to ya (pun intended).
Is that the "stabilizer" or something else?
Like I said, I know one person who used it in his vehicles and both had major loss of oil pressure, one catastrophically.
__________________
I agree.......Lucas cost my good friend a motor too.
Heavy oil is not allways better. Like mentioned here the passages are smaller in newer engines and heavy oil will not flow as freely to reach upper parts and bearings. It was hard for me to understand untill we tore down a Mod v-10 and noticed how small the passages were.
Don't try to re-engineer just do what the OEM's reccomend. Chances are you will do more harm than good. If you want better lubrication use Mobile 1.
It gets really hot wear i live, so i run 10W40 + 20% lucus.
man that reminds me of a shop owner down the road from us (and i'm right next door to ya in La).......
he bought the truck (f250 V10 CC), i saw it about 3 mo later with the engine jerked out of it, i thought he was parting it out. after i stopped to ask about it he said he was waiting on a new engine........ wiped the cam CLEAN on the old one.......... just happened to ask him what oil he was running........ (now this is from a 25 year ASE certified mech).....
" i only run 20w50 in all my BIG BLOCK trucks....... and 10w40 in the "southern winter"......."
this truck was for sale again about 4 months ago with guess what........ a blown crate engine........ he said it was a bad engine to start with and he'd never buy a POS V10 ever again..........hhmmmm he wanted $13K with a blown engine and knowing that he used 20w50 in a V10......... not a chance!
i use 5w20 motorcraft with no issues what so ever.
__________________ Jason 2000 F250 LARIAT, CC, SHORT BED, 4X4- V10, 9"lift, 4.56, 39.5 IROKs, BANKS kit, FM 40 2003 Excursion XLT - V10, 4.30's w/ LS, pretty much stock (for now) V10 sound clips "If at first you don't succed.........do it the way your wife told you to"
