4 speed Brownie? - Ford Truck Enthusiasts Forums
4 speed Brownie?
Old 10-08-2001, 08:55 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
4 speed Brownie?
I had some time to kill yesterday, and I decided to wander around a friend of mine's yard full of heavy equipment type junk.... Anyway, I happened upon an old L8000(Mid 80's maybe?) And, I noticed that it had a two stick setup, with the second stick marked 1,2, O/D and Direct, and, a quick peek through the remains of the floorboard got me thinking.... I think I could probably sling it under the F100, divorce mount the t-case, get a short tailshaft for the 435(maybe with the mounted E-brake, my normal setup is constantly seized...) and put tht brownie in between, I need a new rear driveshaft anyway(an 8.8 is longer than a 9") and a couple more wouldn't hurt.....
Evan MacDonald
82 F100 FlareSide 4wd
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
SBC valved 66 240 head
Headlight Relays - Delanty Style
NP435(6.69 low)
NP 205
3.55 Geared ARB'd 9" & Trac-Locked TTB
31x10.50/15 Cooper Discoverer LT's
Old 10-10-2001, 02:34 PM
Charles-65F350 Charles-65F350 is offline
Charles-65F350 is starting off with a positive reputation.
4 speed Brownie?
It's a moderate amount of work, but it can be done... I put a 3 speed brownie behind my NP435. You will need to fabricate front and rear crossmembers at a minimum. Since mine came without a shifter I also had to buy a 3-speed shifter, make mounts for it, and make shifter linkages from 1/2" steel rod and clevises. The front driveshaft was easy, two splined yokes slipped together (only 11" center to center). As you noted, the rear driveshaft can be made by any shop. Speedo cable won't fit either so you'll need an extension or a new one, and probably the speedo gear won't be right either and may be hard to find, so a correcting ratio joint will be needed.
It's very annoyingly whiny in 0.85 OD though. Not sure if this is "normal" or if it could use a set of bearings. It isn't synchronized but that's relatively easy to get used to. There is no noise in direct, and UD (2.35:1) is very nice for backing up really slowly. If you put one in let us know how it went!
Old 10-10-2001, 05:36 PM
82F100SWB's Avatar
4 speed Brownie?
No need worrying about the speedoemter, it's driven off of the transfer case, and it's wrong anyway.... I'm gonna see about sandwiching the brownie in between the 435 and married 205, I don't want to have to get another t-case if I don't have to, as I have re-built this one and converted it to twin-stick. Gear noise is not a problem for me, I can't hear much over the exhaust, not even my 223,000 mile NP435..... And, I kinda like gear noise anyway....
Evan MacDonald
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
NP435(6.69 low)
NP 205
Old 10-10-2001, 08:07 PM
beau2 beau2 is offline
beau2 is starting off with a positive reputation.
4 speed Brownie?
7 speed // 4 + 3 overdrives Leroy Unlisted Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 27 04-08-2016 01:02 AM
NP435 T_Cooksey88 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-06-2016 12:46 PM
3 Speed Brownie Transmission MJD Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 04-25-2012 01:26 AM
np435 trans like a brownie box? 46autocar 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-09-2010 12:42 AM
Pics of my 78 are up 82F100SWB 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-21-2002 03:53 AM
Tags
3spd, attachment, automatic, box, brownie, browny, f150, ford, l8000, np435, overdrive, parts, put, speed, speedometer, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
