Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 03:00 PM
Kennewick's Avatar
Kennewick Kennewick is offline
Kennewick is starting off with a positive reputation.
73 F100 360 sudden rough and tap
Long story short I bought this 2 year sitter and after some basic clean up of the carb, replace the accel pump and check and a complete change of all the fluids, I got this thing running great at about 10 btdc. Very smooth and almost no ping. The next morning I fire it up to check the choke and it goes to fast idle starts making a knocking noise right off and running very rough. Starts right up and idles but rough and the knocking has subdued to a good tapping at rpm. Before no smoke but now a little blue white.
Thats its condition now. Facing the engine it sounds like the left side. I pull the #1 spark plug and its wet. I checked and it has spark but no change in the sound of the idle. If I pull any other wire it wants to die.
I will put a timeing light on it when I get home. Any thoughts please.
  #2 (permalink)
Old 06-29-2009, 04:42 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Stuck lifter. You can pour detergent additive into it and hope it breaks loose. With that and the smoke, I'd start planning a rebuild.
  #3 (permalink)
Old 06-29-2009, 08:30 PM
MeanGene427 MeanGene427 is offline
MeanGene427 is starting off with a positive reputation.
Considering it sat for a couple years, a valve my have stuck in it's guide before the oil worked it's way down to lube it, pretty common with long sitters if the intake or exhaust was open to air. May have tagged a valve with the piston, and/or bent the pushrod- you'll find out when you pull the valve cover
  #4 (permalink)
Old 06-29-2009, 10:07 PM
Kennewick's Avatar
Well facing the engine on the #1 side with the valve cover off the second valve in has a bent pushrod, as in toast. Not sure what to do next??? My guess is stuck valve alright.
  #5 (permalink)
Old 06-29-2009, 10:23 PM
Kennewick's Avatar
So I have been driving the truck around for a few days and it has been running smooth. Any ideas on what I should do next.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
