Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 02:44 PM
Cdy1 Cdy1 is offline
Cdy1 is starting off with a positive reputation.
confused :/
ok.. i changed the guages in my 95 bronco today due to an old shifting prob and i was recomended to replace them.. the shift prob is fixed but now the volts hit 8(below normal) and the batt dies... so i got a used alternator and its still doin it. everything was fine before the guages exsept the shifting prop.. anyone have any ideas????
__________________
1995 Eddie Bauer Bronco 5.8L 351W E4OD
  #2 (permalink)
Old 06-29-2009, 02:54 PM
shawn_N's Avatar
shawn_N shawn_N is offline
shawn_N is new and has a neutral reputation at this point.
voltage regulator maybe?
  #3 (permalink)
Old 06-29-2009, 03:28 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
1992 Ford Bronco
greystreak92 is gaining momentum as a positive member of FTE. greystreak92 is gaining momentum as a positive member of FTE.
Check for corrosion and good connections to the voltage gauge. The wiring in my 93 had gotten bad enough at one point that my voltage reading wouldn't even register on the gauge but everything else was fine. Turned out the wiring to the gauge itself was so corroded that not enough was getting through and it was putting additional draw on the battery.
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
UPDATED! Big Bronco FAQ's
  #4 (permalink)
Old 06-29-2009, 10:43 PM
checked all that... nothing... put the origional guages back in the truck and everything works fine..................
__________________
  #5 (permalink)
Old 06-30-2009, 12:35 AM
McLeod's Avatar
McLeod McLeod is offline
McLeod is gaining momentum as a positive member of FTE.
Sounds like you got a cluster out of a 92-93 truck
92-93 are the same
94-95 are the same
96- some say stand alone and some say same as 94-95????
An incorrect gauge cluster will create a charging problem.
Did you replace the individual gauges or the entire cluster assembly?
What year vehicle did the replacements come out of?
__________________
Just Say No!
'93 F 150 - 5.0, E4OD, 4.56, 33" & 4" Rancho lift
'95 Bronco - 5.8, E4OD, 3.55, 265/75 15 Goodyear Wrangler SilentArmor (excellent tire)
'67 Bronco Roadster, 351w, 4.11's, 5 inch Skyjacker lift
  #6 (permalink)
Old 06-30-2009, 02:03 AM
haha wow.. whole cluster out of a 93
__________________
  #7 (permalink)
Old 06-30-2009, 09:24 AM
McLeod's Avatar
That's the problem.
Now, you could take those gauges and install in your 95 cluster and you will be OK.
You can also repin your wiring connectors to make it work.
Go to this thread for wiring diagrams for the different years:http://www.ford-trucks.com/forums/85...ster-help.html
__________________
Just Say No!
  #8 (permalink)
Old 06-30-2009, 02:56 PM
i swaped the guages... ty ty ty for the info!!! everything works
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
