Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-03-2009, 11:22 AM
pawpaw pawpaw is offline
pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE.
Nope no dis-assembly required, you did good on cleaning the MAF sensor.
Good to hear it seems to start & idle better, but the P0171 & P0174 codes are for a lean condition on boh cyl banks & suggest a vacuum leak somewhere,
I agree, the PCV & it's pumbing belong on your suspect list, as well as any vacuum lines to things like the vapor recovery system, brake booster, AC/Heater controls & intake manafold gaskets.
You might consider trying a rigging a propane "sniffer" tester, with an unlit propane torch & a length of tubing attached as a probe, & check around vacuum leak suspects, to see if idle speed increases as the engine gets a sniff at the vacuum leak. Prpoane won't hurt the O2 sensors, cat converter, or underhood rubber, plastic or composit parts that some sprays can.
If it seems to be leaking around the intake manafold, maybe try re-torquing the intake manafold fastners to spec.
The rubber hose from the air tube, running over to the valve cover is the fresh air intake hose for the PCV system.
Not sure of the OHC 4.0L PCV set up, so you need input from an OHC 4.0L owner!!!!
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles but trifles make perfection & perfection is no trifle
(Ben Franklin)
Our signature is a sign of a job completed autograph your work with excellence
Tags
2003 , explorer , ford , idles , ranger , rough
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
