Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil and Lubrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Oil and Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 01:16 PM
SOPBeer SOPBeer is offline
SOPBeer is starting off with a positive reputation.
1987 351 Windsor Oil intake to Carb
I have 87 E250 351w with a hose originating from the oil fill tube and entering the carburator intake housing. I'm finding that within a few thousand miles of driving the air filter is completely soked with oil and sitting in basically an oil bath inside the housing. The performance is gone and gas mileage drops to around 8mpg. There doesn't seem to be a PCV valve in the system, doesn't look like it was ever designed with one. Is there any harm in diconnecting the hose from the oil fill tube and replacing with a breather? Any other suggestions how to prevent oil from filling the carburator air filter and filling the housing?
  #2 (permalink)
Old 07-02-2009, 09:42 AM
jimandmandy jimandmandy is offline
jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE.
There was a PCV valve designed into the system. Look at the rear of the passenger side valve cover. If custom valve covers were installed, maybe the PO thought the hose to the air cleaner was sufficient. It is not. Air should flow FROM the air cleaner housing TO the crankcase and FROM the PCV to manifold vacuum. Just putting an open breather on will still result in blowby not being properly cleared, with the resultant oil dilution with water and acids, as well as a mess.
Jim
  #3 (permalink)
Old 07-02-2009, 09:55 AM
Thanks I found the PCV valve and replaced it. I will see if that does the trick.
  #4 (permalink)
Old 07-02-2009, 05:29 PM
Freaksh0w's Avatar
Freaksh0w Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
Great, sounds like that should fix the problem.
__________________
1986 F-150 5.0 EFI XLT Lariat 4x4
NP435/NP208/9" 3.50
"Custom Exhaust" and leaf spring overloads
31x10.50 15" Nothing special, but it's a damn good truck.
Tags
351 , fill , oil , windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
