Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 11:47 AM
fp_5's Avatar
fp_5 fp_5 is offline
fp_5 is starting off with a positive reputation.
Carb Identification
I recently bought a '77F250 2wd truck. The truck was originally a 351M but at some point a rebuilt 460 was put in by a Ford dealer(I think).
I need to rebuild the Carb and would like to do it myself with the proper kit. Unfortunately there is no tag on the carb and no stamping that i can find on it other than "Motorcraft". How do I figure out which carb this is. I would upload pictures but I haven't been able to do so for weeks now( have asked moderator to investigate). Is there an online reference with diagrams that I can use as I believe that there were several different carbs that are similar but not identical.
any help would be great!
Thnx,
Frank
__________________
'76 F100
'64 Falcon
'47 & '48 Ford Fordor Super Deluxe
'77 F250 Super Cab
" I thought I was wrong once but,...I was mistaken"
  #2 (permalink)
Old 06-29-2009, 01:04 PM
FordNFishinLover's Avatar
FordNFishinLover FordNFishinLover is offline
FordNFishinLover is starting off with a positive reputation.
If its the stock carb than its prob the 2 barrel motorcraft 2100 or 2150.
I'd double check to see if they didnt stick the carb id tag into the glove box or something of that sort. If not id run by a mechanic and have him look at it and im sure he could help you out.
I hope you figure it out, good luck!
__________________
1981 Ford f-100 302 windsor/C6/3.25/9.0 rear
Bass, walleye, catfish, and trout, im tellin you now you'd better look out! You were safe in the lakes when i was home wishin. But be on your guard cause im goin fishin!
  #3 (permalink)
Old 06-29-2009, 01:11 PM
fp_5's Avatar
Forgot to mention that it's a four barrel(spread bore)...........
I'll look through the stuff I got with the truck one more time, maybe I'll get lucky and find a tag.
frank
__________________
'76 F100
'64 Falcon
'77 F250 Super Cab
  #4 (permalink)
Old 06-29-2009, 07:57 PM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE.
Check out your thread in the 73-79 forum.
  #5 (permalink)
Old 06-29-2009, 08:55 PM
460swmo 460swmo is offline
460swmo is starting off with a positive reputation.
http://www.carburetor.ca/carbs/tech/...350-index.html
Motorcraft 4300 or 4350 is what you most likely have. Every one of those carburetors I ever had was difficult to deal with and I ended up going aftermarket.
  #6 (permalink)
Old 06-29-2009, 09:57 PM
fp_5's Avatar
thanks 460swmo,
Thats the one! The newer spread bore, the lower photo.
Seems odd that they"re both 4300's?? Seems like there's a lot of info on that site, I'll poke around and see what I can find out. If I can find an application guide hopefully only one kit will work a Ford truck of the era.
wishful thinking maybe?
thanks again
frank
__________________
'76 F100
'64 Falcon
'77 F250 Super Cab
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
