Quote:
Originally Posted by wptski
I can't speak for other years but a '09 you can't accelerate without rear wheel torque or said better you can't even touch the accelerator pedal without generating rear wheel torque. I'm talking about dry pavemnt. It just shouldn't be that easy to generate rear wheel torque. I don't see the need to waste gas.
Power sent to the wheels with more grip suggests wheel slippage, where's the slippage on dry pavement?
It senses which tires have the most grip and sends more power to those tires.
Since the rear is only getting 20%, they have more grip so when you accelerate, it sends more torque to the rears because they have that most grip.
Because the front gets 80% and the rears only get 20%; the rears have the most grip.
The difference in fuel milage from an AWD setup like the Escape has to the on-demand setup like what some Explorers have and what the Expedition has, where it doesnt send power to the fronts until the rears lose traction is marginal because even with the on-demand setup, you are still spinning the front differential and halfshafts all the time.
Personally, Id gladly give up a little gas milage for the sure-footed traction on snow/ice that AWD gives you.
My girlfriends V6 4WD Escape gets 25 mpg on the highway. I recently switched it over to Motorcraft 5w-20 semi-synthetic oil and air the tires up to 38 psi and it gained about 40 miles of range. When she used to fill the gastank it estimated a range of 290 miles and now when she fills it up, it estimates a range of 330 miles.
If gas milage is that much of a concern, dont buy a 4WD Escape.
