Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 01:08 AM
furz4 furz4 is offline
furz4 is starting off with a positive reputation.
91 351 W wont start or run
I am having problems getting my 91 F250 running. Engine cranks and has spark, 40 PSI on the fuel rail and does start and run when you feed some gas into the intake. It will kinda try to fire and will run a little if you keep the starter engaged and work the throttle some. Acts like it is not getting any gas. It seems like I have some kind of problem firing the injectors, with 40 PSI on the rail there should be plenty of fuel. Was running fine and just quit and now refuses to start. Was thinking perhaps TPS or some other sensor problem as all of that stuff is original as far as I know.
  #2 (permalink)
Old 06-29-2009, 05:48 AM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
Yes it could be the TPS or the ECT sensors but also the computer.
Any codes?
Check an injector with a noid light or a neon test light on the non red wire side of an injector and see if it flashes while the engine is cranked.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 06-29-2009, 10:11 AM
I havent pulled the codes yet didn't have my reader as truck died 90 miles from home. Am just trying to determine if this will be a field fix or trailer back. What is the likelyhood of the computor just dying? Truck was running ok.
  #4 (permalink)
Old 06-29-2009, 11:58 AM
subford's Avatar
Not as likely as the TFI or PIP sensor in the distributor doing it.
Are you sure you have good spark?
Did you check it with a spark tester?
Rent a noid light from an auto part store to check if the computer is firing the injectors.
They will give you back your money when you take it back.
__________________
subford@gmail.com
  #5 (permalink)
Old 06-29-2009, 03:15 PM
Am pretty sure the spark is good, it was very visable even in daylight, and the engine did run when manually primed with gas. I think I have an injector test light somewhere from before so will check when I get it home. I was thinking about the sensor in the distributor as well. Am going to trailer it home but need to make sure this old beast is going to be reliable going forward once I get it going agian. I can't complain too much as it has almost all old sensors except O2 with 240 K on the truck. Probably time to just replace them for good measutre.
  #6 (permalink)
Old 07-05-2009, 11:38 AM
Ok got back from vacation and pulled codes got 552, 126, 553. By my OBD 1 book code 126 is cylinder identification failure is the only one that would seem to apply. I still dont seem to be firing the injectors as truck will only run with primed with gas.Any ideas on what is most likely cause.
  #7 (permalink)
Old 07-05-2009, 11:56 AM
subford's Avatar
How did you get these codes?
Most 1991 trucks only have two numbers in the codes.
__________________
subford@gmail.com
  #8 (permalink)
Old 07-05-2009, 03:14 PM
Used ford code reader for 81-95 vehicles.
  #9 (permalink)
Old 07-05-2009, 04:10 PM
Have a little more information. I checked the injectors with a test light and I get no flashing at all just a solid light that is on as soon as the key is on.
  #10 (permalink)
Old 07-05-2009, 04:22 PM
subford's Avatar
Quote:
This would be true for one side of all the injectors but the other side should flash.
__________________
subford@gmail.com
  #11 (permalink)
Old 07-05-2009, 04:24 PM
Thanks I'll go check the other bank.
  #12 (permalink)
Old 07-05-2009, 04:31 PM
subford's Avatar
I meant the other side of each injector.
__________________
subford@gmail.com
  #13 (permalink)
Old 07-05-2009, 04:41 PM
Cant get to any wiring on that side due to the intake manifold, will keep trying but it's all pretty buried on that side, did jump the EEC relay to rule that out with no effect.
  #14 (permalink)
Old 07-05-2009, 04:47 PM
It seemed both were solid on the test light but will check again.
  #15 (permalink)
Old 07-05-2009, 04:53 PM
Both sides of the injectors have solid test light. If the TPS was bad it would still flash a little right?
Tags
1996 , 351 , 351w , 91 , code , diagnosis , f150 , ford , location , pip , problems , reader , sensor , start , starting , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
