Go Back   Ford Truck Enthusiasts Forums > Misc. > Paint and Bodywork
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Paint and Bodywork SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 01:02 AM
nhawlman nhawlman is offline
nhawlman is starting off with a positive reputation.
How do I remove 1992 tailgate Ford decal?
I just bought a 1-owner 1992 F-150. I want to replace the damaged FORD tail gate decal. I tried the hair dryer removal with a plastic putty knife. But the decal disintegrates. It wont peel off, and takes forever. Is there a better way?
What happens if I fasten a Carburetor Cleaner or Acetone-dampened cloth patch over it with magnets to loosen it ? Will it affect the paint?
Thanks,
Nevin
  #2 (permalink)
Old 06-29-2009, 01:08 PM
*2fords* *2fords* is offline
*2fords* is starting off with a positive reputation.
I don't know if it will help you or not. But I just stripped all the factory decals and pin striping off my 92, with a pressure washer. It wasn't intentional when I started, I was just trying get a bunch of rust colored crap off my truck. Anyway, it took all the decals and pin striping off without much effort.
You can also get a bbuffing wheel for a drill that is made to take off stickers and side molding glue, etc. I assume it can be found at any parts store or auto body supply.
__________________
92 F-150 flairside all stock 5.0 auto 2WD
93 F-250 4x4 flatbed 5.8 auto KnN, throttle body spacer, underdrive pulleys, flowmaster
73 Jeep CJ5 springover axles, reversed front shackles, 304, T-18, lockers front/rear, 4:29 gears, 33s
87 Toyota Tercel Tuner some engine mods exhaust
  #3 (permalink)
Old 06-29-2009, 08:56 PM
Hokiewheeler Hokiewheeler is offline
Hokiewheeler is starting off with a positive reputation.
Eraser wheel. They work very nice. It goes in a drill chuck, but has a threaded stud on it. Apparently there is a threaded adaptor for your drill, but I don't know what it's called. There is also an air tool to run them in, like a die grinder but slower rpm. You will find them at any auto body supply shop. When you use it, start from one end of the decal with the wheel rotating into the decal and move in the direction the wheel turns. You might need a wax/grease remover or light buffing to remove the smudges from the wheel. Don't hold it in one spot or it might burn the paint, and if you have a lot to do will burn out your drill.
  #4 (permalink)
Old 06-30-2009, 12:33 PM
Beechkid Beechkid is offline
Beechkid is gaining momentum as a positive member of FTE.
3M makes an adhesive remover that works well also.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #5 (permalink)
Old 07-10-2009, 01:59 PM
ottawaguy's Avatar
ottawaguy ottawaguy is offline
ottawaguy is starting off with a positive reputation.
I worked at a dealership when I was young and we used razors to catch the edge of decal to pull off the outer layer of the decal and then used acetone to remove all the glue. I can't remember if we used the acetone to soften up the edges a little first.
__________________
Dave
1994 F-150 XL Supercab 4x2 300CID-I6
1994 Bronco XLT 4X4 302CID-V8
  #6 (permalink)
Old 07-13-2009, 03:55 PM
Witty73's Avatar
Witty73 Witty73 is offline
Witty73 is starting off with a positive reputation.
Are you sure its a decal? can you get a picture? what trim level is the pickup?
__________________
10 F250 Supercab 5.4.....D.O.G
03 Eddie Bauer Expedition
01 Mustang GT Ragtop
01 F350 Crew Cab V10
76 F350 Dually
74 F100 project
  #7 (permalink)
Old 07-19-2009, 10:31 AM
uncle.stosh uncle.stosh is offline
uncle.stosh has a good reputation on FTE. uncle.stosh has a good reputation on FTE.
Quote:
All 92+ used decals on the tailgate.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
