Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 12:19 AM
fe freak fe freak is offline
fe freak is starting off with a positive reputation.
mystery engine id
im new - i have a ford fe engine with id as follows-- c3ae 6015h--- this motor ran like a top -but upon further inspection needs a complete rebuild --- any help in identifying this block would be greatly appreciated
  #2 (permalink)
Old 06-29-2009, 12:38 AM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Any other id on it? A tag on the coil mount on the intake? What carb, 2v or 4v? OEM 2v FE in '63 should be a 352. 390s were all 4bbl that year methinks. BUT, just because that casting number indicates '63 does not mean it was cast in '63. There should be a date code on the block near the pan rail where the starter bolts up. Note also the "H" at the end indicates a revision to the part. More info here:
http://www.mre-books.com/interchange/interchange11.html
The basic FE rule is you have to measure the bore and stroke. In your case, if you measure the stroke only via wire through the plug hole, you have a pretty good chance of ID'ing it as a 352 with a 3.50 stroke, or 390 with a 3.78 stroke. A 427 would have the 3.78 stroke, but it isn't a 427.
  #3 (permalink)
Old 06-29-2009, 06:55 AM
FFR428's Avatar
FFR428 FFR428 is offline
FFR428 is gaining momentum as a positive member of FTE. FFR428 is gaining momentum as a positive member of FTE.
The C3AE-6015-H is a 390 PI service block.
__________________
68 Cougar XR7 GT. 454" tunnelport in progress.
  #4 (permalink)
Old 06-29-2009, 07:56 AM
FFR428's Avatar
Quote:
Actually 63 and earlier blocks have the date code on the side of the block. Not by the oil filter adapter pad like 64 and later blocks. Just to clear that.
__________________
  #5 (permalink)
Old 06-29-2009, 10:43 AM
MeanGene427 MeanGene427 is offline
MeanGene427 is starting off with a positive reputation.
Should make for a sweet engine, great candidate for a 410 conversion- those early thick-wall blocks are strong. The C1AE heads are a decent starting point, too, big ports like a low-riser, but standard valve sizes. There's a slim chance it may have the nubs for cross-bolts inside- never know until you look. One thing to be aware of, is it should have the two-bolt side mounting flanges, instead of the later 4-bolt setup, so if it goes in a later pickup, you may have to tinker with the mounts a bit. When I put the '64 427 in my early '77 highrider, a small adapter plate of 1/4" steel did the trick
There's a bunch of different C3AE-6015-? blocks, lots of transitions/changes in '63. I got lucky on one, coded as late 406, with 427 bore cores and standard 427 bore, and has the cross-bolt nubs, but never drilled for cross-bolts- yet. As I have a 406 Galaxie, that one is tucked away in the store room- sure miss the days when you could pick up cross-bolt caps from grenaded 427's for $50
  #6 (permalink)
Old 06-29-2009, 04:50 PM
Quote:
Thanks for the correction.
Since it is a PI block, would it be a solid lifter motor?
  #7 (permalink)
Old 06-29-2009, 06:03 PM
FFR428's Avatar
The H block being a service replacement was a hyd block but could be used as a solid lifter app by blocking the lifter oil passages. Multiple applications. It replaced the C3AE-6015-E solid lifter PI block.
__________________
Tags
427 , c3ae6015a , ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
