Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 09:52 PM
Smokin' & Strokin' Smokin' & Strokin' is offline
Smokin' & Strokin' is starting off with a positive reputation.
Diesel Bronco
Anyone have a rough idea of how much it would cost to drop a 7.3 IDI diesel into a bronco?
  #2 (permalink)
Old 06-29-2009, 10:54 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
depends on U. do you plan on doing all the work yourself like weld,fabricate etc etc...
well to do it right would run $5000 - $8000, i say this because not only do you need to get the motor to fit, wired up and such but you also need to strengthen the frame, upgrade to 1 ton axles front/rear, get a different tranny etc..
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #3 (permalink)
Old 06-29-2009, 05:16 PM
Diesel Bronco
Well.....forget that. I knew iy wouold be expensive, but didn't think it would be THAT expensive. Oh well, I'm perfectly fine with finding on that has a 400 or a 460, not like you buy a bronco for good mileage anyway.
  #4 (permalink)
Old 06-29-2009, 05:44 PM
kenpobuck kenpobuck is offline
kenpobuck is starting off with a positive reputation.
I did mine for about $3500. I bought a donor 86 F250 4x4 with a 6.9 and swap out the axles, motor mounts, ttb for the dana 50 front end, core support etc. Most of the money went into engine parts (the donor cost me $1100) while I had it out of the truck just to be safe. I did do all the work myself and if you use a stick or a C6 these old IDI's only need one wire to keep them running. You can swap out the whole wiring harness but I didn't. Also you can do some upgradeing to thses engines (like turbo it) and get some awsome results as well as keep real decent mpg's.
__________________
DON'T BUY IT ..FAB IT!!!!
88 Bronco XLT 6.9 IDI, C6, Dana60 rear, 50 front, 3.55 gears, 33x12.5x16.5's. built by me becuase I just had to!
Kentucky Chapter Member
  #5 (permalink)
Old 06-29-2009, 07:15 PM
johnnyrocket's Avatar
johnnyrocket johnnyrocket is offline
johnnyrocket is starting off with a positive reputation.
Quote:
I would love to see some pictures. Do you have any?
  #6 (permalink)
Old 06-29-2009, 09:10 PM
No I don't. I still have a lot of body work to do to the truck. I might get some on here soon though, if I can figure out how lol. With the 3/4 ton suspesion under it, it sits up pretty good now and that is changing soon as well I hope with 4" body and 6" suspension lift. It is great to live in a common wealth that has no bumper laws!
__________________
  #7 (permalink)
Old 06-30-2009, 06:00 AM
b-uno's Avatar
b-uno b-uno is offline
b-uno is gaining momentum as a positive member of FTE.
the frames are pleanty strong for the 6.9 and 7.3 idi diesels. i swapped on in my 75 crew cab ford, and am in the process of putting one in my 78 bronco now.
RAy
__________________
"LOOK AR ME!!!"
  #8 (permalink)
Old 06-30-2009, 09:21 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
1992 Ford Bronco
greystreak92 is gaining momentum as a positive member of FTE. greystreak92 is gaining momentum as a positive member of FTE.
Apples and oranges when you are talking the difference between the 78-79 frames and the 80+ frames. Keep in mind that the SMALLEST available engine in the 78-79 models was a big block V8. The frames in these trucks HAD to be able to handle that kind of weight and torque.
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
UPDATED! Big Bronco FAQ's
  #9 (permalink)
Old 06-30-2009, 09:16 PM
The frame under my 88 is the same as that of the 86 F250 donor I used just shorter. All the swapped parts were measured out for the fit from the same pionts on both. The front end was put together the same on both, even the rear srings wrer a direct swap no alterations needed at all.
__________________
  #10 (permalink)
Old 07-01-2009, 11:40 AM
but the frame itself is boxed more on the 3/4-1 ton frames. also the D50 really isnt much of an upgrade over the D44 TTB front end. if the bronco is used as a DD and doesnt see anything more then gravel roads at best then the half ton frame is probably fine. you start bouncing around a bunch and wheel the bronco and the frame and suspension wont hold up in the front.
__________________
  #11 (permalink)
Old 07-01-2009, 05:30 PM
As I said before the frame on the 86 f250 and my Bronco where identical in the front, the same hieght, the same width, the same boxed areas and all. As for the D50 it is alot beefier than the D44 that was under the truck, and I swapped in the front leaves so as to get rid of the arms. My Bronco has seen some pretty rough stuff (nothing like extreme) I use it as a truck. By this time next year the whole frame on my truck will be boxed.
__________________
  #12 (permalink)
Old 07-01-2009, 10:32 PM
helirich helirich is offline
helirich is starting off with a positive reputation.
Theres a 96' diesel Bronco on ebay right now. It looks and sounds nice. No reserve.
__________________
90' Bronco, 351, MSD Ign., SS 3" exhaust,
38" x 15.50 R15 Dirt Grips, 14" x 15" Alcoa wheels
6" lift w/ cutout flares, 40 gal. fuel tank
F diff - lockright locker, 4.88's
R diff - Powertrax locker, 4.88's
Cast diff cover w/ carrier braces
Rear full float axles, truss, Above spring traction bars
  #13 (permalink)
Old 07-01-2009, 11:49 PM
1992 Ford Bronco
As for the D50 it is a lot beefier than the D44 that was under the truck, and I swapped in the front leaves so as to get rid of the arms.
Yeah and it has NO provision for using coil springs. People berate the TTB setup in its half-ton form... have you actually looked at the ridiculousness of the TTB LEAF-SPRUNG D50?! Its a silly setup! The movement of the TTB axle halves deliberately twists the spring eyes because of the radial movement. Leaf springs are not designed to move like that in the first place. Its the reason folks prefer to stay with or even swap to coils if they don't have them. Front leaves went the way of the Dodo for a reason. The radius arms on the TTB D44 are far better equipped to handle the proper movement and cause no harmful twisting or tweaking of the springs. Apologies for going on like this but the D50 TTB setup is the worst offense Ford ever committed in the area of front suspension in a truck in my opinion. It is contrary to the whole idea of making things move in sync. Eh, take my rantings for what they are worth guys and gals.
__________________
  #14 (permalink)
Old 07-02-2009, 09:15 AM
special_k's Avatar
special_k special_k is offline
special_k is starting off with a positive reputation.
Oh man, I haven't been here in awhile, and thought I'd come to ask about buying a donor 250 diesel for the drivetrain. Looks like I was beaten to the punch. Was thinking also about that new raptor.....could be fun. I used to have a lightning, so a big fan of svt.........An offroad lightning meant for off road racing?
__________________
92 Bronco. 302. E40D.
33x12.50 All Terains
K&N Filter.
Hopefully soon, Headers, Flowmasters, Suspension lift, 4.56 gears, aussie lockers, 35's, grill guard, balanced and blue printed stroker with a nice cam!!!
Alway factor in Murphy's Law: If something can go wrong, it will. Just be ready!
  #15 (permalink)
Old 07-03-2009, 05:05 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
What mpg are you getting with a 6.9 in it?
Tags
69 , 78 , 86 , 92 , bronco , core , d44 , diesel , diseal , end , ford , frame , front , strengthen , support , ttb , width , worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
