9-11 MPG with a 95 F-150 300 L6 5spd - Ford Truck Enthusiasts Forums
Old 06-28-2009, 09:06 PM
SammichTheStout's Avatar
SammichTheStout SammichTheStout is offline
SammichTheStout is starting off with a positive reputation.
Truck has some type of performance muffler that I am going to change out for a stock unit, I know it needs an alignment, it has 120,000 miles on it, so it could probably use a stronger ignition system. It needs a valve cover gasket but I don't think it will effect mileage. I replaced the K&N filter with a stock unit because I have never had a performance filter that gave better mileage than stock. I run 40PSI front and 38PSI rear on 31" BFG Long Trail T/As. My driving is mostly city with a little highway. I know 300s should get better mileage. I'd like to know which of the factors above is the most likely culprit
Old 06-28-2009, 10:24 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Check fuel presure and pull the codes, that's the best way to start to diagnose your problem.
Old 06-28-2009, 11:45 PM
95 F150 Dude 95 F150 Dude is offline
95 F150 Dude is starting off with a positive reputation.
I just got back from a 400 mile trip in my 95 F150 4.9 E4OD w/ 3.31 gears and got 17.75 mpg running 75-80 w/ the A/C on. You should be getting better mileage than that.
Old 06-29-2009, 12:17 AM
Towmanjbo's Avatar
Towmanjbo Towmanjbo is offline
Towmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to all
What size tires were stock for that truck? When I corrected the speedo my mileage jumped 3-4 mph
Old 06-29-2009, 01:03 AM
Ravenwood Ranch's Avatar
Ravenwood Ranch Ravenwood Ranch is offline
Ravenwood Ranch has a good reputation on FTE.Ravenwood Ranch has a good reputation on FTE.
hell my diesel gets better than that
Old 06-29-2009, 08:14 AM
Quote:
Original tire size is 235/75/15, there are 31/10.5/15s on it now. I know I should be getting better mileage than that. Even without driving on the highway at all, I should be getting better mileage than that.
Old 06-29-2009, 11:03 PM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
my 300 gets around 11-12...with 210000 miles and a leaky head gasket among other things...ill let you know when i rebuild it haha
Old 06-29-2009, 11:16 PM
FlaredFun's Avatar
FlaredFun FlaredFun is offline
FlaredFun is starting off with a positive reputation.
Between the tire size and whatever gearing you are running may be a big part of it.
The gearing may be loading the motor up too much and not letting it stay in the power range it was intended. Like someone else said early, if you are not correcting for the difference in actual mileage from the speedo, then that will definitely change things.
A good old tune up will usually help any engine, unless you have recently done this to it. Just some ideas. Good luck.
P.S. My truck gets between 17.5 and 19 MPG depending on how big of a hurry I am in. It has 275-60-15 tires on it. So when I am just cruising along, it gets pretty decent for a truck, BUT when I get in a hurry, it likes to drink the gas.
Old 06-30-2009, 02:48 AM
Towmanjbo's Avatar
Quote:
Those are the same tire sizes I had, when you update the speedo constant in the speedometer that will change the mileage by 3-4 at least.
Look here: http://www.ford-trucks.com/article/i...ND_BRONCO.html
That is what I did. Do that it's easy.
Old 06-30-2009, 10:52 AM
I think the first thing I'm going to do is a Tune Up and Alignment, next will be the exhaust followed by going back to the original tire size. If that still doesn't fix it... Well, I'll see to that if it happens.
Old 06-30-2009, 11:19 AM
Conanski's Avatar
WHY not do the easy things first.. like pull the codes... BEFORE you spend any money. If you find a problem then you can address it directly instead of just shooting randomly in the dark.
Old 06-30-2009, 11:36 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
i will add:
Old 06-30-2009, 11:37 AM
That'l be included in the tune up.
Old 06-30-2009, 12:06 PM
Conanski's Avatar
And just so you know it's not hard and requires no special tools. Find the EEC test harness on the drivers side inner fender and jumper the STI and Sig-Rtn lines with a piece of wire or paperclip. Turn the key to run and count the flashes on the check engine light. You can cycle the key and count them as many times as needed to get it all right. Post up the results you get here and we'll help sort it out. Your truck should have 3 digit codes with each digit seperated by a short pause and individual codes seperated by longer pauses.
Old 06-30-2009, 09:02 PM
mattri mattri is offline
mattri is starting off with a positive reputation.
Damn that sucks. My 95 F150 4.9 mt 2wd dances around 20mpg. I'll hit 21 21.5 every now and then but that's about it. Truck has 166k bone stock. Did a tune up a cple months ago but it didn't really change anything. Don't know what your driving style is like but I drive like an old man, it helps.
I-6 myth? Joe Carson 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-21-2010 01:24 PM
I need some Fass help. brickie 6.0L Power Stroke Diesel 4 04-25-2009 11:06 AM
Fuel system parts sizing, GPH and PSI Pele Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 02-07-2007 12:20 PM
Windsor build specs- torque/mileage roger dowty Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 04-29-2006 01:38 AM
"97" Ranger 4.0 (Splash) exhaust rfrench1 Ranger & B-Series 5 04-14-2004 01:54 AM
Tags
12mpg, 150, 1995, 1996, 300, 5spd, 91, 95, f150, ford, gear, l6, mpg, ratio, stock, v8, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
