Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 08:34 PM
tttanker tttanker is offline
tttanker is starting off with a positive reputation.
F-150 weight
Info you! 2009 F-150 XLT Supercrew, 4x4, 5.5 bed, 5.4, max tow pkg, 3.73 axle, XLT chrome package, 35 Gals of gas, weighed in at 5740 lbs. Someone asked but couldn't find thread. Hope this helps
  #2 (permalink)
Old 06-28-2009, 09:26 PM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO is starting off with a positive reputation.
Quote:
Your is lighter than my 08...It weighed in at 6200 before picking up my last load of rock.
  #3 (permalink)
Old 06-28-2009, 09:41 PM
With me in the truck it showed 5940 and I weigh in at 205 so it was pretty accurate. I was a little surprised at the weight also.
  #4 (permalink)
Old 06-28-2009, 09:58 PM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
something is off there
my 2006 Screw FX4 w/ Luxury Package, with <1/4 tank of gas: was 6,000 lbs by itself...nothing in it but the spare. I had to pay to ship it from Seattle to Honolulu...better believe that puppy was every bit of 6k all by itself
and the 09's are even heavier than prior generations
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..F'ing quick
Currently deployed. See y'all on the flip-side.
  #5 (permalink)
Old 06-28-2009, 10:07 PM
Bsimmer3000's Avatar
Bsimmer3000 Bsimmer3000 is offline
Bsimmer3000 is starting off with a positive reputation.
Whats you payload sticker say? Is it close to your left over GVRW?
  #6 (permalink)
Old 06-28-2009, 10:46 PM
Sticker on the door says pax and cargo not to exceed 1392 #'s ( Iassume that's the pay load sticker)
  #7 (permalink)
Old 06-29-2009, 04:17 AM
tylus's Avatar
gross allowed weight on the 09's is 7,200 for a screw
so that puts you at 5,800 for curb weight...which is close with the paper specs I've seen on Edmunds.com. They say a Screw XLT should be about 5,600 lbs
did Ford do some Gastric bypass on the 09's that we're unaware of?
__________________
  #8 (permalink)
Old 06-29-2009, 04:44 AM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is online now
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
ford said they were lightening them up....that was the reason for the new frame design and more use of high strength steel.....
09's should weigh less than 08's......
That said....my 07 weighed in at 5950 last year with me in it.....which comes out to about 5700 without me....20 inch rims and all.....i don't know how some of you guys have 6100+ lb trucks...i can't think of anything that i don't have that weighs anything... except maybe the 6.5 ft bed....but that can't add more than 100-150 on...
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
  #9 (permalink)
Old 06-29-2009, 04:48 AM
Ryan50hrl's Avatar
http://www.edmunds.com/used/2007/for...846/specs.html
Gross weight minus max payload should be 5700.....and this should be the heaviest F-150 available...
__________________
2005 XLT scab -
  #10 (permalink)
Old 06-29-2009, 10:39 AM
Not sure what density E-85 is but say it's 6.0 that put's the 30 plus gals of fuel around 180-190 lbs which puts GVW around 5560 if they figure GVW with tank empty. I was looking at the numbers to see if my 09 would pull my small horse trailer and horses ( 5000Lbs) several times a year. Looks like the numbers are okay. It didn't come with a brake controller, so I put one in that was OE and it slipped right in and computer programmed just fine. My 09 has the Max tow package with 18 inch wheels so I believe I'm set. Great truck nd it's a pleasure to drive.
  #11 (permalink)
Old 06-29-2009, 02:50 PM
Power Kid Power Kid is offline
Power Kid is starting off with a positive reputation.
They got lighter with exception of SCrew.. Remember 6" longer and new frame crossmember.
  #12 (permalink)
Old 06-29-2009, 04:18 PM
cpdorroh's Avatar
cpdorroh cpdorroh is offline
cpdorroh is starting off with a positive reputation.
Quote:
That was my impression as well. However, looking at the weights some guys have posted, it appears that the SCrew may have lost some too, or at least not gained any. If an extra 1 foot of bed and frame only adds 100-150 lbs as some would assume, I'd bet an extra 6" of cab wouldn't add in much more than that. Factor in the weight-saving measures, and maybe the new SCrew is about the same weight?
Also, based off of what tttanker showed on the scales with his truck, the payload stickers must be pretty close. If so, that means my truck weighs about 5925 lbs, and it's got about every option (moon roof, man step, etc) except the 6.5' bed. Compare that to Ryan's truck, and it looks like a 225 lb increase though.
__________________
2009 F-150 Lariat, SuperCrew, Navigation, 5.4L, 4x4, 3.55LS, 5.5' bed, man step, A.R.E. LSII tonneau, Rhino Liner
Previous Ford trucks:
2004 F-250 Super Duty, King Ranch, 6.0 PSD, 4x4, 3.73LS
2001 F-150 Super Cab, XLT, 5.4L, 4x4, 3.55LS
  #13 (permalink)
Old 06-30-2009, 10:18 AM
Ryan50hrl's Avatar
I wonder how much of that 225 lbs is attributed to the gas tank being full or empty....afterall a 30 gallon tank could cause that difference
__________________
2005 XLT scab -
  #14 (permalink)
Old 06-30-2009, 01:58 PM
osteodoc08 osteodoc08 is offline
osteodoc08 is starting off with a positive reputation.
Not sure if it helps but my 2006 Lariat Screw 2wd 6.5' bed with nearly empty tank weighted in at 5300# at the county dump.
I can see how 4wd and a full tank of fuel could push you close to 6000#
__________________
2006 F150 SuperCrew Lariat
2006 Jeep Grand Cherokee Overland
  #15 (permalink)
Old 07-03-2009, 09:43 AM
Whiteline's Avatar
Whiteline Whiteline is offline
Whiteline is starting off with a positive reputation.
My '09 screw, 4x4, 6.5' box with the tank full of fuel and me out of it came in at 5975 lbs. Leaves me 1200 lbs of payload according to the sticker.
I've hauled a number of times with it and it handles that payload weight and more very well, way better than the '08 GM I was driving.
Tags
allowed , f150 , ford , truck , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
