Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 07:44 PM
SeannyBoy84's Avatar
SeannyBoy84 SeannyBoy84 is offline
SeannyBoy84 is starting off with a positive reputation.
Exclamation Truck Won't Start: Theft Light Blinking, Fuel Pump Relay...
Hey everyone, my truck won't start and I need some insight.
I was driving home on the highway the other night, my check engine light on, and the engine died. First thing I noticed is that the "theft" light would begin blinking with the key in the "on" position". Also, in the "on" position, the #4 relay (fuel pump) in the power box under the hood would continuously click/rattle. The truck would not start.
Took a look at it after it was towed home. The battery seems fine. The truck turns but it doesn't start. We smelled a lot of gas and found that there was fuel dripping around the exhaust manifold area. I'm not sure if this relates to the relay. Tried replacing and that didn't work.
I miss her already and any advice would be great here. Let me know if you need anything else. What else should I take a look at, should I check any fuses, etc. Thanks.
__________________
97 Expedition 4.6 4x4
  #2 (permalink)
Old 06-28-2009, 08:05 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
Was the CEL on BEFORE or after the engine died? If before, get it scanned so you have that data available.
Fix the fuel leak first. That way, it won't do an "up in smoke' on you.
Try swapping the PCM power relay with another identical relay that isn't critical. Basically anything except the fuel pump relay.
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 07-01-2009, 09:31 PM
The CEL went on at the same time the engine died. There was no sputtering or any other signs that my truck would die, it just did. I tried replacing the PCM relay and they didn't work either.
__________________
Tags
150 , 1999 , blinking , expedition , explorer , f150 , ford , fuel , light , pump , relay , start , starttheft , theft , truck , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
