Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 07:44 PM
77_150_460 77_150_460 is offline
77_150_460 is starting off with a positive reputation.
How can I silence a 460?
I am looking for a muffler with dual 2.5" inlets that will make my 460 fairly quiet without significant restriction. I am aiming for a dual inlet because that is how the exhaust is set up right now (no Y-pipe). I would ideally like dual outlets as well, seems that would be the best for flow, unless I had a larger outlet.
I'll be running a simple setup with dual outlets infront of the passenger rear tire to keep things cheap and simple.
Any input appreciated, my neighbors will also appreciate it since the old rusty muffler is now sitting in the bed
  #2 (permalink)
Old 06-28-2009, 09:29 PM
gthbryce's Avatar
gthbryce gthbryce is offline
gthbryce is starting off with a positive reputation.
So your not running a cat?
__________________
1989 F-250 Xlt Lariat C6auto 4.10axle ratio 460ci-v8 50,000Miles
  #3 (permalink)
Old 06-28-2009, 09:45 PM
ArdWrknTrk's Avatar
ArdWrknTrk ArdWrknTrk is online now
<--Dog is my Co-pilot
ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold
No cats with a GVW over 8500...
Why not just 2 mufflers with the oval vertical?
There's room, I've thought about doing it myself.
You could weld the flanges of your old muffler onto them.
Edit: what about this 370-429-460 bus muffler w/ a 3 1/2" outlet?
http://www.unitedmuffler.com/images/...us_ford_04.gif
__________________
Jim
'87 F-250 4V 460, T19, 4x4, 4.10 sterling 10.25" - Lil' Red
http://i246.photobucket.com/albums/gg117/donjamer/FTE%20Pics/blumax500-1-1.jpgFTE Fraternity of Blue Max
  #4 (permalink)
Old 06-29-2009, 02:18 AM
Bear River Bear River is offline
Former Vendor
Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE.
Larger mufflers will help more. Especially having one muffler on each pipe, however that can be expensive. Having cats will make a huge difference. What year is yours?
I cannot vouch for its sound on a cat-less 460, but our 22" WickedFlow mufflers are reasonably quiet.
  #5 (permalink)
Old 06-29-2009, 08:12 AM
ArdWrknTrk's Avatar
Quote:
Originally Posted by Bear River View Post
What year is yours? .
I'm assuming that 77_150_460's ride is a 1977 model.
__________________
Jim
  #6 (permalink)
Old 06-29-2009, 08:19 AM
Wow, quick replies!
Yes, it is a 1977 with no cats.
I have considered a bus muffler, that is what used to be on the truck, but it was so rusty when I bought the truck that I can not be sure how quiet it ever was. It did have many chambers and seemed to be relatively free flowing though.
My only reason for not preferring two oval mufflers next to eachother is cost. Seems that the cost of a nice set of two mufflers will be greater than a quiet but good flowing single muffler with dual inlets.
Thanks for all the replies - all input welcome!
  #7 (permalink)
Old 06-29-2009, 09:11 AM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
This is about the quietest flowmaster you can get and it has a lot of capacity. Its pricey but less than what the price on the link says. A 2.5" pipe can easily be expanded to 2.75".
http://www.flowmastermufflers.com/pr...oducts_id=3330
I see no problem with running dual 2.5" dual in/ single 3" out muffler either with a 3" tailpipe. The 460 doesn't rev that high in stock form to need a tailpipe larger than 3".
Also if you want a mellow exhaust note, exiting the exhaust in front of the rear wheels is a bad idea. The exhaust will be louder exiting in front of the rear wheel than behind it.
  #8 (permalink)
Old 06-29-2009, 10:34 AM
Former Vendor
Seeing that it is a '77, I would not recommend cats, to many things to go wrong.
I second that, exiting the pipe in front of the tire is what you do when you want it louder. If you want to mellow it out, go behind the tire. I would also second that running a single tailpipe will help with the volume too, it condenses and smoothes out the tone, and helps the muffler do its job.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
