Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 07:20 PM
zachsherman88 zachsherman88 is offline
zachsherman88 is starting off with a positive reputation.
popping sound from a cylinder
Hey guys i just put in a new crank kit and HV oil pump in my 400 because of the low oil pressure i was getting before so now i am running around 70 psi when cold and about 20-30 psi when hot i also want to add that i put in full synthetic valvoline 10w-30 after i put the new parts in was running fine for the first 2 days but this morning when i retorqued the heads and rockers when i started it after it started popping from the passenger side rear of the motor as your looking at it from the front of the truck i took the valve covers off and retorqued the rockers and checked the cylinder plug which has oil on it... now whats the most likely to cause this i also put in new valve stem seals since this cylinder had the same problem in it before? i checked compression and it went up to 140 psi and let it sit for about 10- 15 min and it only leaked about 5 psi.
  #2 (permalink)
Old 06-28-2009, 08:01 PM
daddy172005's Avatar
daddy172005 daddy172005 is offline
daddy172005 is starting off with a positive reputation.
Not sure what you mean by "POPPING" but could be the guides or seats in the head. Could also have piston slap.
__________________
Mason
74 F100 302
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
