Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 06:42 PM
spoogie spoogie is offline
spoogie is starting off with a positive reputation.
Shake of doom
me again,
my 2003 F 4X4 4.2 has the death shake about 40mph then
gets better at 60 or so up to 175 or so. (speedo dead, might be +- 100 mph) I've had the tires balanced, front end checked and straightened out.
It still shakes hard enough to make my Miller foam. What do I check now?
  #2 (permalink)
Old 06-28-2009, 09:46 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
1998 Ford F-250
Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of
U joints can create a nasty vibration if frozen or just plain toast. Is this a stick or a automatic?
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #3 (permalink)
Old 06-28-2009, 09:52 PM
Hm, it's a 5 speed.
You think a u-joint would come and go with speed?
It's another thing to check. Thanks for your help!
  #4 (permalink)
Old 06-28-2009, 10:30 PM
papajoemrt's Avatar
papajoemrt papajoemrt is offline
papajoemrt is starting off with a positive reputation.
Get down there and give your driveshaft a jerk or two.
Could the driveshaft be out of balance?
To check if your driveshaft is out of balance drive it into a pond, lake, or other body of water and when you salvage it from the depths your driveshaft will be balanced.
__________________
2002 F-150 Screw
Kenwood DDX512, Pioneer Doors, Image Dynamic Subs
Dumped Flowmaster Super 40
Trans-Go Shift Kit
Gotts Intake Mod
  #5 (permalink)
Old 06-28-2009, 11:35 PM
What a idea! Water soaking! By God, I never thought of doing that, again!
Your just freaking amazing! That you for your wisdom and forsight.
Jay
  #6 (permalink)
Old 06-29-2009, 09:36 AM
Just a follow up on the rolling earthquake. I layed under her a gave the shaft a good hard shaking, front and rear, and , as always, nothing moved. Any thoughts other then a good soaking? This should be easy for you guys. I mean it is a death shake then smooth as glass......???????
  #7 (permalink)
Old 06-29-2009, 12:09 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KY KR lover
2002 Ford F-150
KingRanchMan02 is gaining momentum as a positive member of FTE. KingRanchMan02 is gaining momentum as a positive member of FTE.
If the tires were not rotated when they were balanced, then rotate them. If that doesn't help, them pull the drive shaft out and check the U-joints with the drive shaft out of the truck. They should move in all directions smoothly. Good luck!
__________________
John, aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege, 5.4L 3.55 LS, 4x2, Diablosport Predator Programmer, K&N filter.
FTE Ride of The Week, 4/20/09 !!!
`08 Mercury Sable Premier, 3.5L Duratec, 6 speed auto
  #8 (permalink)
Old 06-29-2009, 12:56 PM
Thanks friend,
swapped tires front to rear after jacking the whole truck up on jack stands and running her in 4X4 and finding a shake in the left front wheel
which upon closer inspection found a bend in the rim. put it on the back, still some shake but at least it does'nt make your hands go numb.
Jay
  #9 (permalink)
Old 06-29-2009, 01:23 PM
Joe Finn's Avatar
Joe Finn Joe Finn is offline
Joe Finn is starting off with a positive reputation.
How in the world did they balance the tire and not find a bent rim?
__________________
'97 F150 4x4 XLT 4.6L 3.55 LS Supercab
  #10 (permalink)
papajoemrt's Avatar
Of course I was kidding about the water soaking idea.
__________________
2002 F-150 Screw
Trans-Go Shift Kit
Gotts Intake Mod
  #11 (permalink)
Old 06-29-2009, 01:28 PM
Quote:
That is the million dollar question. Maybe it was a balanced wobble
  #12 (permalink)
Old 06-29-2009, 09:26 PM
1998 Ford F-250
You will want to replace that wheel. If it's shaking that much it can still cause a seal to blow out in the rear. Extreme, I know but still possible.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
  #13 (permalink)
Old 06-29-2009, 11:40 PM
papajoemrt's Avatar
A balanced wobble? is that even possible?
__________________
2002 F-150 Screw
Trans-Go Shift Kit
Gotts Intake Mod
  #14 (permalink)
Old 06-30-2009, 07:35 AM
Joe Finn's Avatar
Quote:
I suppose it's possible, but even the worst POS balancer will find a bent rim in about 2 seconds. Maybe they were bubble balanced?
__________________
  #15 (permalink)
Old 06-30-2009, 12:39 PM
I dont know guys, just goes to show you that just cause sombody says somethings right, its not really is. Second guess everything, even from experts.
Jay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
