Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 03:31 PM
MorseM MorseM is offline
MorseM is starting off with a positive reputation.
Cylinder 1 misfire, spark looks fine
Hi all,
I have a 1996 Aerostar w/ a 4.0 engine (170,000 miles on engine, new spark plugs, distributer cap, wires, rotor within 10,000 miles) that is running rough and showing "Check Engine". The fault codes are "P0301 Cylinder 1 Misfire Detection" and "P0171 System too Lean (Bank 1)". I changed one of the oxygen sensors (the one just after the catalytic converter) several hundred miles age but the fault light returned almost immediately.
I took the spark plug out of the # 1 cylinder (passenger side, closest to radiator) and laid it against frame, turned starter; nice blue spark.
How do I diagnose the problem?
MorseM w/ a good ol' Aerostar
  #2 (permalink)
Old 06-28-2009, 08:26 PM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
welcome morseM,
simple things first.
it's either spark or fuel.
since you've confirmed you've got spark to #1, then suspect fuel.
how do all the plugs look? same color?
when was the MAF last cleaned/replaced? search forum threads for directions how to remove the MAF element and soak in carb. cleaner
2nd CAT sensor located after the CAT is only a monitor on 1st sensor and CAT correct operation, has nothing to do with correct fuel mix. replace first CAT sensor, they only last 50k>100k miles and usually die slowly affecting fuel mix and operation.
after these simple fixes, switch injectors between #1 cyl and another. does problem follow injector?
glad you're aboard.
i had the same problem with my 96 4L AWD last year, defective new spark plug ign wires. replaced with Motorcraft.
best source, our site sponsor RockAuto
use ONLY Motorcraft or Autolite plugs and wires in these 4L EDIS Aeros. the high eng. comp temps and high spark voltages destroy other wire sets
use lots of silicone dielectric grease in the spark p. wire connectors, both ends
  #3 (permalink)
Old 06-28-2009, 09:55 PM
93nighthawk's Avatar
93nighthawk 93nighthawk is offline
93nighthawk is starting off with a positive reputation.
Welcome MorseM!
Quote:
Originally Posted by MorseM View Post
Hi all,
Um, last time I checked, the 4.0L did not have a Dist Cap or rotor. Are you sure you don't have a 3.0L?
Like XLT said, you replaced the wrong O2 sensor. You need to replace the one before the cat. Cleaning the maf will help too. You might also want to check your vacuum lines. One might have slipped off when you did plugs/or on its own accord. This would also cause a lean condition.
Keep us up to date.
__________________
'97 Ford Aerostar AWD 4.0L v6 AT 84k mi
'07 Ford Taurus SE 3.0 Vulcan ATX 42k mi, Last of the original Tauri
My Car Domain
The Possum Aero-Van!
  #4 (permalink)
Old 06-28-2009, 10:27 PM
Thank you both for the sound advice;
96_4wdr:
-The spark plugs were all of uniform color when I changed them and the wires seemed ok, they both had about 70,000 miles on them. I bought them at the local discount auto parts chain store. After I got the codes read this past week, I pulled # 1 spark plug and it smelled of fuel.
-I have never cleaned the MAF; but after your comments, I think I will be doing that this week!
-I will also change the front oxygen sensor. Is it ok to buy these at the discount chain? The ones they sell are Bosch.
93nighthawk:
-My mistake; no distributer cap, no rotor; it is a 4.0. I have several older cars to keep running for/with our children and got confused on what was done to what car.
-When I change the front Oxygen sensor I will look for open vacuum lines.
Thanks again for your responses and expertise, I will start back on it tomorrow and let you know how it goes.
  #5 (permalink)
Old 06-29-2009, 02:15 AM
Bear River Bear River is offline
Former Vendor
Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE.
Upper intake manifold leaks are a fairly common problem. However they most often result in lean codes, stumbling or pinging, and not misfires. The problem is most likely either a problem in the ignition system or a fuel delivery problem. The cam position sensor can also be involved however. I have seen a bad sensor result in misfires or misfire codes.
  #6 (permalink)
Old 06-29-2009, 04:59 AM
96_4wdr's Avatar
i believe Bosch builds FoMoCo's OEM O2 sensors, i've had good luck with them
i second the vacuum line failure/problem check. 13 year old rig and the heat/temps under the Aero hood guarentee vac. line failure. replaced all of mine several years ago
these 4L Aeros with OBDII systems display all types of strange symptoms with a 1 cylinder miss; Overdrive lockout, no torque converter lockup, shift problems. the van weight accentuate the symptoms
the HAL computer goes crazy trying to control all.
did the miss/problem show up after new plugs/wires?
what brand of plugs?
  #7 (permalink)
Old 07-01-2009, 10:26 PM
Aeroman59's Avatar
Aeroman59 Aeroman59 is offline
Aeroman59 is starting off with a positive reputation.
Although you can put any plugs you like in an Aero , THEY WONT LAST as long as Motorcraft! in some cases less than 50% . I would swap to Motorcraft or Autolites first, lets go from there.
Speaking from the experiance I've had with my 3L when I've had any misfire (which is 3 times in 300,000 plus Kms) it's always been traced to plugs as the cause, in one case I had one come loose, this caused a month of headache until I finally took a wrench to it, a 1/8 turn extra fixed that problem. Bosch O2 sensors are fine. They are good for about 100K. A faulty front o2 sensor could easily cause the PO171 code, as well as a vac leak. I've had no problem with my injectors yet. You might find you have two seperate problems here.
Good luck,
Aeroman..
__________________
Green-96, XLT 2wd, 3L Vulcan, from Ontario, Canada
All original powertrain except alternator & starter motor. 320,000 kms & going strong !
When describing the 96 Vulcan engine, the word Bullet proof is not too much of an exageration !!! Just a little TLC goes a LONG way.
  #8 (permalink)
Old 07-02-2009, 06:15 AM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
EEC computer has MOSFETs inside to actuate injectors w/o current contror witroll, so bad injector wiring ore bad inj. coil cause no codes, exept of P0301, so step #1 is to check pulses on injector with o-scope and if pulses are OK, check injector impedance, If you see elkectrically injector is OK may be mechanicalli it is bad ore clogged. Well, try comoression test too.
__________________
_____________________________________
And makes us rather bear those ills we have
Than fly to others that we know not of?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
