Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 03:03 PM
DCRB DCRB is offline
DCRB is starting off with a positive reputation.
Just curious, Crown vic rear end...??
Just curious as to weather or not any one has contemplated trying to fit a crown vic rear axle assy. to their aero?? i was at the j/y yesterday and was noticing that they use a coil spring and shock assy. for the suspension, and maybe they have other similarities to make it swapable to an aero? i like their rear discs the most... and limited slip... just wondered what ya'll think
__________________
93 3.0l xlt extended aerostar
mods: 800 watt sound system. - 2" catback exhaust w new flexpipe and cherry bomb muffler. - 4g alt. wiring - Gutted stock airbox.
"88 civic "STD PLUS!!"
  #2 (permalink)
Old 06-28-2009, 06:06 PM
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is starting off with a positive reputation.
They are fundamentally different designs.
The Aero uses 2 lower trailing links with a single upper link that perform double-duty with the 2 lower trailing links to locate the axle housing both laterally and rotationally. The housing will have only a single mounting point for that one upper link, in addition to the 2 for the lower links.
The Crown Vic rear is a little different; It uses the more traditional 4 trailing link with (I think) a Watts (or Panhard) lateral link. The combination of 2 upper and 2 lower links provide fore-aft and rotational location of the axle housing, while the Watts link provide the lateral location. So its rear axle housing will have mountings for the 2 upper arms and the Watts bell crank (or Panhard pivot) in addition to those for the 2 lower links.
You will have to install an upper mounting point for the Aero's 3rd link onto the CV's rear axle (and maybe remove the mounts for the CV's 2 upper links) to make it work on the Aero, or convert the Aero's rear suspension to use the 4 link plus Watts link of the CV.
If you want the disk brakes, I think you may be able to find other vehicles that have brakes that will fit with minor modifications. I think maybe some of the Explorers may be adapted without much work.
But ultimately, rear disks on an Aerostar will not be too effective, since most of the braking is done by the front due to the weight transfer. They will try to lock up the rear tires more readily.
  #3 (permalink)
Old 07-03-2009, 06:04 AM
V8aerostar V8aerostar is offline
1991 Ford Aerostar
My Garage
V8aerostar is starting off with a positive reputation.
the areostar work van has an 8.8 rear end. and i hope it bolts up. i have one sitting behind my van now. im waiting to put the 5.0L in first. it looks exact.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
