Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 06-28-2009, 01:15 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
Garage is empty, add now
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
biglick truck pull update!
went to the BL truck and tractor pull last night and I'm proud to say that other than the dodge exibition puller "Joey King" the ford boys brought it home! we need more ford participation down there it has turned into a dodge swamp!
__________________
Ashley
2000 F250 Destroked "Frankinstien" CR 5.9 Cummins 631 HP 1389 lbtq
2003 explorer limited AWD V8
1990 7-UP mustang 5.0
  #2 (permalink)
Old 06-28-2009, 08:46 PM
79 Trailer Special's Avatar
79 Trailer Special 79 Trailer Special is offline
2003 Ford F-150
79 Trailer Special is starting off with a positive reputation.
u should have let me know u were goin, im 5 min from there.
__________________
They call me Rick....along with a few other names I cant repeat
I'll keep my guns, my freedom and my money, you can keep your "change"
  #3 (permalink)
Old 06-29-2009, 09:40 AM
MAKO314's Avatar
I always go if they're haveing the truck pull I'm there. there is a big money and points pull down there in september plan to go, it will be good!
__________________
Ashley
  #4 (permalink)
Old 07-02-2009, 07:35 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
Dang I pulled last time, were you there? I was the one that got the poor guy in the harley truck fixed up.
__________________
-Scott
SOLD 2-28-11.....
'06 F250 CC/SB PSD. 2'' lift, Bilstein 5100's, Dual stabilizers, 20'' Harley wheels, 35-12.50 MT ATZ's, 08 Mirrors, ARP studs, EGR delete, 4'' MBRP, X3 with custom tunes, Full gauges, scangauge II, Coolant filter, Red top Optimas, DC 185a alt,
  #5 (permalink)
Old 07-02-2009, 07:53 PM
******** width="240" height="180" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/v/1101698156441" />******* src="http://www.facebook.com/v/1101698156441" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="240" height="180">********>*********>
__________________
-Scott
SOLD 2-28-11.....
  #6 (permalink)
Old 07-02-2009, 09:37 PM
MAKO314's Avatar
I was there when the HD truck flopped, what happened to him? yes I was there this past saturday also.
__________________
Ashley
  #7 (permalink)
Old 07-03-2009, 07:12 AM
slash31938's Avatar
slash31938 slash31938 is offline
slash31938 is starting off with a positive reputation.
i oughta bring one of our 7-ton trucks down there, show yall boys what a real truck can do!
__________________
1980 F250- 351M, T18, NP208 (Sold)
1978 Bronco Custom 400M, NP435, NP205 6" Lift, 35's (Sold)
1986 Bronco EB 302, AOD, 9" all kinds of cool stuff.
  #8 (permalink)
Old 07-03-2009, 09:12 AM
Quote:
The cinter section of the rear diff spun on the axle tubes, pointing the pinion nearly straight up. Obviously when this happened it snapped the driveshaft like a toothpick. If you saw the HD truck brake, you saw me pull then because I pulled right before him in the silver crew cab
__________________
-Scott
SOLD 2-28-11.....
  #9 (permalink)
Old 07-04-2009, 02:46 PM
fuzzy1626's Avatar
fuzzy1626 fuzzy1626 is offline
fuzzy1626 is starting off with a positive reputation.
Why don't they have any truck pulls in the western part of the state? I'll have to check to see how far Biglick is from me.
__________________
Tony 1994 F250 XLT ext. cab,long bed,7.3 IDI factory turbo,4x4,manual hubs,E4OD,4.10 gears, K&N air filter,Hayden 679 trans. cooler,PSD oil filter,coolant filter and vac. operated heater shut off valve, manual glowplugs,Autometer water temp.,trans. temp., and pyro in three guage pillar pod, Autometer mechanical oil pressure under dash with twin vac/boost guages,TruxPort tonneau cover,straight piped,189,000 miles and counting. 88 Ranger 2.0, 5 speed,147,000 mi.,bought new.NC Chapter Member,IUE Retired, NRA Life Member,USMC.
  #10 (permalink)
Old 07-04-2009, 02:56 PM
Quote:
just about 2 hours. Im from Morganton originally and it takes me just over 2 hours to get from here (about 15 min from biglick) to Morganton which is about 30 min west of hickory. Just get on 77 south, get off on 70 east, jake alexander to hwy 52. 52 to 24/27, turn left at red cross and your there.
__________________
-Scott
SOLD 2-28-11.....
  #11 (permalink)
Old 07-04-2009, 03:38 PM
fuzzy1626's Avatar
Quote:
Thanks 06silvercrew; Just got off the Biglick web site. Have marked the Sept. date on my calendar. We have a race at Elk Creek on the 27th, but if we haven't got the new engine done, I will be at the pulls for sure.
__________________
  #12 (permalink)
Old 07-07-2009, 08:50 PM
Here is the vid of my truck at Biglick.
http://www.youtube.com/watch?v=4oE2vheyb0Q
__________________
-Scott
SOLD 2-28-11.....
  #13 (permalink)
Old 07-08-2009, 10:51 AM
MAKO314's Avatar
what do you guys think about PULLING "LOL" together a gtg for the truck pull? there seems to be some intrest in this king of redneck sports and we need more fords to make a showing down there. let me know what you guys think about this and we'll try to get something together.
__________________
Ashley
  #14 (permalink)
Old 07-08-2009, 11:01 AM
DaMole's Avatar
DaMole DaMole is offline
2006 Ford F-150
DaMole has a very good reputation on FTE.DaMole has a very good reputation on FTE.DaMole has a very good reputation on FTE.
We have one down this way in Elizabeth City to if anybodys ever out here.
http://www.mcttp.com/
__________________
Joel
2006 F150 XLT 4X4 - AS 2 1/2 Leveling Kit with AS Blocks, Wet Okole Covers, Volant CAI, Edge Evo, Flowmaster 40 Duals, Husky Toolbox, FX4 Rims & Tires.
1993 F150 XLT 4X4 - 4" Rancho Lift, 33-12.50 BFG, Pioneer Stereo
Proud Club SNL Member #10
  #15 (permalink)
Old 07-08-2009, 11:04 AM
fuzzy1626's Avatar
Sounds like a winner to me........
__________________
Tags
1990, big, carolina, custom, disel, ford, lick, nc, north, pull, pulling, pulls, ranger, taylorsville, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
