Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 01:54 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE.
Low refrigerant?
The A/C in my truck(1993 F-250) only blows 60* at idle, but will cool down to 45* while driving. Could this be due to a low R-12 level or is something else going out?
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
  #2 (permalink)
Old 06-28-2009, 09:52 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
1998 Ford F-250
Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of Ultramagdan has much to be proud of
I'm thinking fan clutch but to really check your system you need to put gauges on it.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #3 (permalink)
Old 06-29-2009, 02:46 AM
lsrx101 lsrx101 is offline
lsrx101 has a good reputation on FTE. lsrx101 has a good reputation on FTE.
+1 on the fan clutch. Classic symptoms.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #4 (permalink)
Old 06-29-2009, 02:59 AM
1993 Ford F-250
The fan clutch? You mean the airflow through the condenser would make that big a difference? The engine doesn't run any hotter at idle. I'll check it out though. I'll admit to knowing nothing about A/C other than the names of most of the components.
__________________
  #5 (permalink)
Old 06-29-2009, 03:18 AM
Quote:
Yep. Your AC performance at idle/low speed will suffer long before the engine is effected. The fan clutch is actually a wear item and should be replaced every 5-8 years, but nobody ever does. At 16 years, I guarantee yours is weak.
BTW, don't go cheap on the clutch. The ones from the "chain" parts stores are often not much better than your worn OE unit. Get a Motorcraft replacement or Hayden HD or SD unit. It's going to smart a bit on your diesel. I believe the MC clutches are close to $200 for oil burners. Check with one of the site sponsors.
__________________
  #6 (permalink)
Old 06-29-2009, 03:43 AM
1993 Ford F-250
I can get a Hayden SD for about $120, thats not too bad. I'll check it out tomorrow when I'm working on the truck.
__________________
  #7 (permalink)
Old 07-05-2009, 03:08 PM
1993 Ford F-250
Not sure if the fan clutch is bad as it feels pretty tight in regards to spinning, but the water pump was. Plenty of play in the shaft. While replacing that I noticed the radiator was full of crap so now it's getting cleaned. One thing leads to another.
__________________
  #8 (permalink)
Old 07-07-2009, 03:22 AM
1993 Ford F-250
The list continues, radiator can't be cleaned, dimpled core tubes. I got the new pump and new radiator in and was able to confirm the fan clutch is bad as well. I'll replace that tommorrow, making this one of the most expensive questions I've ever asked.
$80-Coolant
$350-Radiator
$25-water pump
$25-new hoses
$120-fan clutch
=$600.
__________________
  #9 (permalink)
Old 07-07-2009, 04:55 AM
$80-Coolant
$350-Radiator
$25-water pump
$25-new hoses
$120-fan clutch
=$600.
Then stop asking questions and turn up the radio, fer cryin' out loud. It's much cheaper that way. Just ask my Ex-Wife.
Sorry, I just had to go there.
That amount is just what you run in to on a 17 YO, used vehicle that hasn't been maintained strictly "by the book" since Day 1. Most vehicles aren't. Even then there are problems once you look a bit deeper than the surface. Mechanical things just wear out, deteriorate and get used up over time. At 17 years, your truck was WAY past due if all of those parts were even close to original.
Compare that cost to a new truck payment, over the next 6 months.
Consider this: By 1980, a large percentage of ~1963 Ford PUs were scrapped because they were plain worn out by then. I remember 1980 very well, and rarely saw a ~63 Ford pickup.
In contrast, in 2009 there are still tons of ~1993 Ford PUs on the road. Even in My area of the rust belt you can't swing a dead cat without hitting 2 or 3 of them.
30 years ago, your 17 YO truck would have likely been long in the scrap yard.
__________________
  #10 (permalink)
Old 07-07-2009, 12:58 PM
1993 Ford F-250
No kidding, hopefully I've got it all covered for awhile. Coolant is so expensive for a diesel that I didn't want to have to drain it again for a long time, especially since it has a service life of 150k miles. The $80 I paid for 8 gallons was a steal since the guys sold it to me at cost instead of the original $17.50 a gallon. Still, I prefer the nickel and dime stuff as opposed to the monthly payment. We'll see if this fixes my A/C problem though, since the wife wont be letting me spend any more money for awhile.
__________________
Tags
1985 , ford , refrigerant , replace , truck , xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
