Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 11:46 AM
paulietools paulietools is offline
paulietools is starting off with a positive reputation.
Correct carb gasket????
In my quest and self education to get my truck running right I have noticed what I think to be the wrong carb gasket by the PO.
I have an Edelbrock 1406 on an Offy dual port aluminum intake. This is all on my 351. The gasket that was installed under the carb is a standard square bore gasket. The intake manifold doesn't have a square bore opening. It isn't the 4 hole style either. It has what I think is a divided square bore pattern.
So my question is:
What sort of issues am I dealing with / creating by using a square bore gasket on a divided bore intake.
It looks like that the center of the card is not sealed against the intake manifold and that air/fuel mistake can pass under the base the carb into both sets of runners.
Edelbrock makes a heat insulator gasket that comes as a divided bore gasket. I am thinking of getting that as I can't find that type of gasket from anyone else.
Any thoughts or comments are greatly welcomed.
  #2 (permalink)
Old 06-28-2009, 05:28 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
If two of the holes are smaller on the intake you have a spreadbore intake. My son has an Offy Port-O-Sonic spreadbore intake and Holley square bore 1460. Holley tech gave me the right number for the gasket and adapter plate. I'm sure Edelbrock will do the same. Try to find which intake it is from comparing on the Offy website. His is mismatched with high rpm intake and doesn't need that on a Bronco. Best choice would be match the carb with a new Edelbrock intake, but that depends on how much money is available.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
