Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 09:15 AM
CK3's Avatar
CK3 CK3 is offline
CK3 is starting off with a positive reputation.
Wheel Offset?
I'm in the middle of installing the Bushwacker Cut-Outs on my '89 B2. The drivers rear of the rig needs a bit of body work. It looks like I'm going to need to buy the wheels & tires before I mount the flares. (I just want to make sure the wheel & flare are centered) I'm going to run SSR 33x12.5-15's. What rim width & offset do you recommend?
I was thinking about 10" rim width but I'm not sure about the offset.
I'm lookin for this look..
Thanks for the help..
  #2 (permalink)
Old 06-29-2009, 11:49 PM
rebocardo rebocardo is offline
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
10" rim with 3 - 3.5" backspacing. Otherwise the tires will rub badly on the front radius arms. The most common ones will be 4-5" of backspacing, which is fine for Jeeps, not a B2/Ranger.
imho, If you are running stock axles that is way too much tire, especially the SSR (nice tires - I have them) for those axles.
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
  #3 (permalink)
Old 06-30-2009, 03:59 PM
CK3's Avatar
CK3 CK3 is offline
I'll be running D35 & an 8.8..
I bought one Cragar Soft 8 wheel from Summit & it came today. It's a 15x10, 4" backspace. I was told on two other forums that running the Rough Country 4" lift, 33x12.5 & the Cragar Soft 8 (15x10, 4" offset) will work fine. ???? I only bought 1 to see if it would fit.. Now I'm not sure what to do..
  #4 (permalink)
Old 06-30-2009, 10:01 PM
CK3's Avatar
CK3 CK3 is offline
I was going to do the axle swap in a couple months. The stockers should be fine for "on road" driving until then right?
I was also thinking about 1/2" spacers & longer wheel studs to fix the offset problem..
  #5 (permalink)
Old 07-03-2009, 10:52 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
Stock offset it 4.5", so you'd want to adjust from there to a more shallow offset, probably around 3.5" at the deepest. I wouldn't run spacers, as they tend to put more strain on your wheel bearings - as does using a shorter offset wheel. You could probably run stock offset if you had a Skyjacker or Duff lift with the extended radius arms, as they are usually curved some to compensate for larger tires.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #6 (permalink)
Old 07-03-2009, 11:24 AM
CK3's Avatar
CK3 CK3 is offline
Quote:
I have the Rough Country 4" lift.. I guess I'll keep looking for wheels..
Thanks for the help guys.
  #7 (permalink)
Old 07-03-2009, 11:30 AM
Welcome. Just want to add that if you don't have extended radius arms, you'll want them. Usually, anything over 2-3" of lift causes a lot of hate and discontent on stock radius arms, and the ride is usually rougher with 'short' arms, not to mention things can break because of the extra stress. Just some food for thought.
__________________
  #8 (permalink)
Old 07-03-2009, 11:35 AM
CK3's Avatar
CK3 CK3 is offline
What are my options for the extended radius arms? I know James Duff, who else makes them?
Thanks
Tags
150 , 2006 , 2009 , arms , breaking , duff , f150 , f250 , ford , james , offset , radius , ranger , rim , stock , truck , wheel , wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
