Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 01:52 AM
blustang6614 blustang6614 is offline
blustang6614 is starting off with a positive reputation.
A4WD Conversion
I have a 2002 XLT that has A4WD with electronic shift option to go to 4H or 4L. I would like to convert it to electronic shift but 2WD and 4H or 4L. I do not have a need for the A4WD and it causes acceleration problems. Does anyone know of a way to convert it that would be practical. Any help would be greatly appreciated.
  #2 (permalink)
Old 06-28-2009, 09:16 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) is gaining momentum as a positive member of FTE.
i dont think it will be practical or cheap to convert a AWD to 2WD.
I would question why this needs to be done. What acceleration problem. I have a 2002 and it has 110k miles on it, no problems. Gets 20 MPG at 60 MPH on the road.
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 190,000 miles
2002 Explorer 4 x 4 4.0 XLT - 120,000 miles
  #3 (permalink)
Old 06-28-2009, 11:03 AM
When I accelerate the transfer case tends to buck if I have to accelerate fast as to say get to speed to get on the highway. It did this alittle bit before i got new tires but more so now after. I got slightly larger tires since they were cheaper but this should not affect since they are all the same size. I went from stock 235 70 r16 to 235 85 r 16. Are you getting that 20mpg highway? I am averaging about 16 highway at about 65? This was pre larger tires. I realize that the new larger tires will also adversely affect the MPG as well but it should not be that much. The main reason I want to get rid of the A4WD is that I know I drive alittle aggressive and it does what it is supposed to do and transfers power to the other wheels. I am also convinced that if the front rotating assembly does not need to get power regularly then I should pick up some MPG if only the rear wheels are powered. Well if its not a relatively simple fix then its not worth fixing if its not broken. Thank you for your input. Any thoughts on upping the MPG? I am usually on top of keeping up with routine maintenance so im not sure what the problem is.
  #4 (permalink)
Old 06-28-2009, 01:37 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
you said it yourself, "I know I drive a little aggressive ".
start driving like you have a raw egg between your foot and the gas pedal, see what difference it makes.
  #5 (permalink)
Old 06-28-2009, 01:57 PM
steve(ill)'s Avatar
i drive at a constant 60 MPG on county highways. very little city driving. 20 miles one way to work. The EXP got 20.5 and 20.0 on the last two tanks. THE F150 with 5.4 got 17.7 on last fill up. over 17 is common in summer.
__________________
  #6 (permalink)
Old 10-19-2009, 09:57 AM
reflex26 reflex26 is offline
reflex26 is starting off with a positive reputation.
Hi Blustang6614. Go to Ford Explorer and Ranger Enthusiast Forums - Serious Explorations and do search for "the brown wire mod".
There several excellent and detailed articles on how to do this.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
