Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 01:12 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
2004 Ford Excursion
My Garage
weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE.
In the market for a 08 F 450 King Ranch
Hello every one,
This week I may be possibly going to look at a new to me 6.4 with 80,000 miles on it. I know the 7.3 inside and out but I am a complete idiot when it comes to the new 6.4. What should I be looking at when I look at this truck? I know the venti mod should be done to it buts that's about it. Any help is greatly appreciated,
Thanks
Nick
__________________
Nick PAA#9
08 F-450 K R 6.4 SPARTINIZED, DPF/CAT GONE
04 X 6.0, 08 towing mirrors, 15k hitch, Firestone air bags
01 X 7.3, TN BB turbo, Dp tuner, ITP RR, RR up pipes, 4 Dipricol gauges,MBRP 4inch, 6637,650 dash with 2 auto meeter gauges, RR boots,
95 F-250 7.3, 6637
  #2 (permalink)
Old 06-28-2009, 02:59 PM
2004 Ford Excursion
My Garage
Bump Please.
__________________
Nick PAA#9
95 F-250 7.3, 6637
  #3 (permalink)
Old 06-28-2009, 03:09 PM
senix's Avatar
senix senix is online now
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
venturi mod, look at the radiator real close, the seams to ensure that is does not have any leaks.
As if it has had the latest pcm updates so you can see the "cleaning exhaust filter" message in the display.
Check out the message center and get to the engine hours, see if it is higher that it should be for the miles. I would think the truck should have around 2500 hours on it.
Ask to see maintance records for oil changes and filter changes.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #4 (permalink)
Old 06-28-2009, 05:15 PM
2004 Ford Excursion
My Garage
Alright thanks. What about soot in the exhaust is that ok?
__________________
Nick PAA#9
95 F-250 7.3, 6637
  #5 (permalink)
Old 06-28-2009, 05:37 PM
senix's Avatar
soot indicates that there may be a issue with fuel trim levels/sensors for the DPF or DPF itself so it does need to be checked.
A little gray is ok.
__________________
  #6 (permalink)
Old 06-28-2009, 08:21 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
SHADE TREEIN SINCE 1957
StanleyZ is gaining momentum as a positive member of FTE.
Hi warrior, I just made the change a week or so ago. Still have my 7.3 and I'm deciding which to keep. The 08 really drives and tows wonderfully and I'm sure the 450 is even better but all this DPF talk has me concerned, not to mention the 12.8 miles I seem to be averaging in routine driving. I can't wait to see what it is when I'm towing. My truck only has 4000 miles on it and when I checked the oil it looked kinda funny. I read on here that there is an issue with leaking injectors that put diesel fuel in the oil pan, hard to get a good reading with that funky oil dip stick but it seemed high on the mark to me so I went to a dealer and got that first oil change on the record by them just to get a relationship going. I have to say it runs and drives nice and towed wonderful, I've had two of those regens or whatever they're called and they were uneventful. I wouldn't have known they were happening except the message board told me. Hope this helps.
__________________
2008 F350 DRW Lariat/ 4.30 Diff/Titan 60 Gal fuel tank/Bone stock running gear and just a little truck bling.
  #7 (permalink)
Old 06-28-2009, 08:42 PM
ruschejj's Avatar
ruschejj ruschejj is online now
2008 Ford F-250
ruschejj is starting off with a positive reputation.
Well StanleyZ and weekendwarrior, I can't keep my mouth shut....
I have run my 6.4 as hard as I know how, never babied, I don't worry about idle time, and I consciously try to blow it up if I think that something could be wrong. Never had any real problem. Yes, the radiator and I lost an EGT sensor.
I understand that the comfort of the 7.3 is real and I respect it. The 6.4 is the best motor and truck I have driven (which is not saying a whole lot, but some).
I know the MPG is crappy and I know that people write about problems, not satisfaction. If you want a new truck you will not get a diesel that gets above 18mpg doing anything. The bowtie/dodge trucks have the same issue. The blue oval just happens to have the best chassis to boot!
I don't really have a bone to pick, just calm down and enjoy the best truck available. sorry to sound gruff. I get tired of everyone complaining about this stuff sometimes.
__________________
'08 F-250 4X4 CC 6.4
RideRite Airbags in Rear w/onboard compressor
Bilstein Shocks, Dual Air Horns (under hood)
Edge Insight Gauge Cluster
4-Way "wig wag" strobe lights
Polk speakers, Kicker 10" sub, 600w amp
  #8 (permalink)
Old 06-28-2009, 08:59 PM
StanleyZ's Avatar
Might otta read mine again, I thought it was pretty positive and warrior hasn't said anything. Down here in Georgia we say 'it's the hit dog that yelps". Now have a nice evening.
__________________
  #9 (permalink)
Old 06-28-2009, 10:37 PM
sbaset sbaset is offline
sbaset is starting off with a positive reputation.
Were can I find the engine hours...I have never seen this in the center display??
  #10 (permalink)
Old 06-29-2009, 05:50 AM
ruschejj's Avatar
2008 Ford F-250
"but all this DPF talk has me concerned"
Stanley, you're right. Most of your post is positive. I got set off by the above quote. Nobody knows what the DPF is going to do after 4 years of service, everybody wants to have problems with it while in warranty.
I am from Georgia. I'm a Dawg, class of '92, and '93, two degrees. I'm also a Vet.
The "hit dog" comment makes a lot of assumptions about somebody you have never met in person. I know my post was agressive but there are over 500 threads in the 6.4 forums on DPF and MPG.
have a nice day
__________________
  #11 (permalink)
Old 06-29-2009, 05:51 AM
ruschejj's Avatar
2008 Ford F-250
sbaset, I think you just have to push the "info" button a couple of times to get engine hours. Be careful if you get into the compass recalibration, it will haunt you for hours unless you complete the process it want you to go through!
__________________
  #12 (permalink)
Old 06-30-2009, 01:08 AM
LOL...thanks for the warning. I will give it a try.
  #13 (permalink)
Old 06-30-2009, 02:08 AM
2004 Ford Excursion
My Garage
Well tomorrow I will be heading to Houston to go look at the truck and I will let you guys know what I find
__________________
Nick PAA#9
95 F-250 7.3, 6637
  #14 (permalink)
Old 06-30-2009, 07:39 PM
StanleyZ's Avatar
have a nice day
Well, since you said all that I can only say one more thing to you: GO DAWGS!!!!!!!!
__________________
  #15 (permalink)
Old 06-30-2009, 09:07 PM
ruschejj's Avatar
2008 Ford F-250
Sic 'em!
I hope your truck is all you expect it should be. Safe travels.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
