Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2009, 01:06 AM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
1995 Ford F-150
My Garage
9.ford.5 is gaining momentum as a positive member of FTE.
vacuum testing on a 300?
anyone know a simple easy way to test for vacuum leaks? is there any way to pressure test the system like you would a coolant or air system?
im trying to find stuff to fix on my 300 that would help the fuel mileage/power output and i am not very familiar with vacuum systems
thanks guys i love learning new stuff about my truck...
__________________
PROJECT and DD---95 ford f150 4x4, 300 INLINE SIX!, 5speed, SAS, 4" lift, 35x13.50 ground hawgs (sooner or later)
PARKED---91 ford f150 lariat, 302 v8, auto, 2wd, rust
PARKED---92 ford f150 xl ext. cab short bed, dual tanks, 302 v8, auto, 2wd, LOUD!, very little rust!
  #2 (permalink)
Old 06-28-2009, 10:01 PM
desperado_18_2000's Avatar
desperado_18_2000 desperado_18_2000 is offline
1983 Ford F-150
desperado_18_2000 is starting off with a positive reputation.
You could always try spraying carb cleaner around the intake manifold and the vac lines to see if it idles up. Also i think a vacuum gauge would show that you have low vac due to leaks.
If you have a Harbor Freight around, a decent gauge is about $15. Just bought one a while back myself.
__________________
Tim
C'mon down and join the fun in the Mississippi Chapter!!
1983 F-150 4x2 LWB 300 T-18 4spd
  #3 (permalink)
Old 06-29-2009, 12:59 PM
rikard rikard is offline
rikard is starting off with a positive reputation.
I use an unlit propane torch to check suspected areas. Much less messy and safer than using liquids.
regards
rikard
__________________
Present-1995 Black F150 SC XLT 300 5 Spd
Past-1994 Red F150 SB XL 300 5 Spd
1983 Red F150 SB XL 302 AOD
1962 USPS 2.5 ton stepvan converted camper
223 3 speed DRW
1956 Red F100 Ma Bell uility bed 223 3 Spd
  #4 (permalink)
Old 06-29-2009, 08:50 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
owned by fords
dustybumpers is gaining momentum as a positive member of FTE.
hook up a vaccume guage. if needle wavers back and fort about 1lb, you have a vaccume leak. steady needle no leak. find the leak by spraying brakeclean on all surfaces, if idle rises, you found your leak
__________________
Charlie
Join the Maryland Chapter click HERE
  #5 (permalink)
Old 06-29-2009, 11:23 PM
9.ford.5's Avatar
1995 Ford F-150
My Garage
cool guys thanks how much do you think a vacuum leak could effect fuel mileage and power, truck still has good power but 12mpg max isnt even close to what other 6s get
__________________
  #6 (permalink)
Old 06-30-2009, 05:45 AM
owned by fords
vaccume leak, timeing, egr, plugge cat, cap and roror, wires, and trans condition all evvect mileage. several problems at once can kill mileage.
__________________
Charlie
  #7 (permalink)
Old 07-01-2009, 01:26 AM
9.ford.5's Avatar
1995 Ford F-150
My Garage
yeah i did the wires plugs and timing but i will do all that stuff again just because i can and im bored, full out tune up/ rebuild in the works. thanks again
__________________
  #8 (permalink)
Old 07-01-2009, 10:32 AM
6CylBill's Avatar
6CylBill 6CylBill is offline
1994 Ford F-150
6CylBill has a good reputation on FTE. 6CylBill has a good reputation on FTE.
I hate to sound redundant because I'm known as the "exhaust" man, but I know your 300 has well over 200K miles..Have your cats ever been replaced? If not, I would put a three-way cat on the list. You will gain a few horse, nothing impressive, but your butt dyno will feel it. I know mine did anyway.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #9 (permalink)
Old 07-01-2009, 12:03 PM
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
i know people that smoke will take a good puff of a ciggarrette and then unhook one vacuum line and breath out into it, if the smoke comes out somewhere else then thats where the leak is.
__________________
  #10 (permalink)
Old 07-01-2009, 01:33 PM
91Bronc300 91Bronc300 is offline
91Bronc300 is starting off with a positive reputation.
Isn't secondhand smoke bad for your engine?
__________________
1991 Bronco; 4.9L; Mazda 5 speed; BW1356, 8.8 open rear; 44TTB open front, 3.55; daily driver
1985 F-250 4x4; 300; C6; BW1345, Ford sterling semi float posi rear; 44HD TTB open front; 3.55; runs
1979 F-250 4x4; 400, NP435; NP205; Dana 60 full float open rear; Dana 44HD open front, project truck
Tags
1983 , 300 , f150 , ford , ford300vacuumleak , inline , leak , lines , test , truck , vacum , vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
