Another transmission question...
The first thing is you have to have the clutch friction disc centered on the flywheel so that the splined hub on the disc is dead in line with the pilot bearing.
Second you must feed the trans into position straight. Look at the edges of the bellhousing as you feed it in, the gap top and bottom and left and right between the faces should be equal at all times and in line.
Third it is a good idea to turn the engine over a little as you feed the trans in to make sure the splines on the shaft and clutch plate mesh easily.
Hope this helps.
Hope this helps.
yz450fpilot
08-09-2011 04:34 AM
Pointa
02-05-2006 06:13 AM
sshannon74074
07-05-2004 04:35 PM
