Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 09:19 PM
Bert01F150 Bert01F150 is offline
Bert01F150 is starting off with a positive reputation.
Cool 2001 Ford F150 EGR code P0401
A while back my truck had code P0401, insufficient EGR flow. I cleaned the EGR valve, tube & all vacuum lines. I had no vacuum, Recently I got the same code. I followed the same steps as before. I now have vacuum but the truck loaps really bad with line connected to the EGR valve. If I disconnect the EGR valve vacuum line, the truck seems to idle a little better. Can anyone make any suggestions as to what could be causing this ?
  #2 (permalink)
Old 06-29-2009, 11:23 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
Hi, and welcome to FTE and the 4.2/3.9 Forum.
There have been several posts here over the years regarding P0401 (and P0402) codes.
While in the 4.2 forum, Click on "Search this forum" the top and type "P0401" in the search box. You'll get plenty to read.
I seem to remember 2 most common causes:
bad DPFE sensor
or
clogged EGR ports
Best of luck with repairs and let us know what you find as the cause.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Tags
2001 , 2002 , code , egr , f150 , flow , ford , insufficient , p0401 , troubleshooting , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
