Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 05:05 PM
vgibbs vgibbs is offline
vgibbs is starting off with a positive reputation.
Interior/running board lights will not turn off
Interior and running board lights will not turn off. Not a door latch problem because the 'door ajar' light in the dash is good. It self tests at start-up and comes on and off when doors/hatch are opened and closed. All door and hatch latches have been cleaned with WD-40. All 5 door lock actuators replaced within the past year. The lights just stay on all the time. The lights will not turn off when the truck is locked or when driving down the road. Also, the automatic timer does NOT shut them off. I have to pull a fuse under the dash to keep the battery from dying, however that same fuse controls the pwr windows and the shift lock. This is a real pain! I think it must be a relay...anybody have this problem or know which relay may be the culprit? Thanks in advance!
__________________
Virg
2000 Excursion XLT, 2wd, V10
2001 30' TrailLite TT
2004 F150 XLT SuperCab, Shortbed, 5.4, 4x4
1989 Shelby CSX/VNT
  #2 (permalink)
Old 06-27-2009, 06:02 PM
myblkex's Avatar
myblkex myblkex is offline
myblkex is starting off with a positive reputation.
Quote:
You have made sure that the interior light dimmer control is not turned all the way up and clicked on right ? That happened to me eariler this week when my 3 year old was playing in my truck and pushed all the buttons
__________________
2000 V10 Excursion 4x4 w/ '05 Conversion
HID's, Cowl Hood, 20% tint, Bilsteins, Helliwig Rear Sway
  #3 (permalink)
Old 06-27-2009, 06:20 PM
Actually, that was the first thing I asked the wife (and checked myself) when she reported the problem...switch is NOT in the manual position. Thanks!
__________________
Virg
1989 Shelby CSX/VNT
  #4 (permalink)
Old 06-28-2009, 01:22 AM
wallz's Avatar
wallz wallz is offline
2002 Ford Excursion
wallz has a good reputation on FTE. wallz has a good reputation on FTE.
The delayed accessory relay is #306. On your fuse cover you can see the # scheme to find it. You could try one of the other relays in its place to see if it makes any difference.
__________________
2002 Excursion, 4x4, V-10, some mods, and many more to dream about!
  #5 (permalink)
Old 07-02-2009, 05:01 PM
Thanks for the help. There is no relay #306 for my truck -- 2000 V-10 2wd. However, there is an accessory delay realy (Relay #5) in the fuse box under the dash. I swapped this out with the rear defroster relay (known good), but it did not solve the problem. There are also two smaller relays in the same fuse box (#1 -- Interior Lamp Relay, and #2 -- Battery Saver Relay) I swapped both of these with like relays from the fuse box under the hood. Again this did not solve the problem.
The Ex is now sitting on the side of the house as pulling fuses everytime we want to drive the truck is just plain annoying.
I really don't want to have to take this thing to a dealer. Anyone have any further suggestions?
__________________
Virg
1989 Shelby CSX/VNT
  #6 (permalink)
Old 07-03-2009, 12:41 AM
Tried cleaning the contacts on the relays; disconnected the battery to reset the GEM/CTM. Nothing changed. At this point I think there must be something wrong with the GEM (Generic Electronic Module) as something is keeping the Interior Lights relay energized all the time. Running board lights are part of this circuit. There has been lots of discussion here about the running board lights corroding, but since they all work and not blowing a fuse, I don't see those as a potential problem. However, I will check/clean those sockets tomorrow just to see. After that I see no choice but to take it to the dealer to see it they can diagnose the problem.
__________________
Virg
1989 Shelby CSX/VNT
  #7 (permalink)
Old 07-04-2009, 10:24 AM
96ozarker 96ozarker is offline
96ozarker is starting off with a positive reputation.
Does your EX have the feature of delaying radio turnoff until you open a door, and if so, does that feature also fail?
__________________
2002 Excursion Limited Ultra
  #8 (permalink)
Old 07-04-2009, 01:21 PM
rdct's Avatar
rdct rdct is offline
rdct is starting off with a positive reputation.
I'll add to list of dumb things you likely already checked:
1) Open and slam your lift gate shut. Had me stumped one night at camping. I heard it latch completely, but it was shut so gently that it didn't make a connection.
2) Spray all your door latches and work them open and closed if #1) doesn't work. That was why the liftgate needed to be shut in a more manly manner
__________________
Ron
2000 V10 4x4 Excursion, Bilsteins, Skyjacker steering stabilizer, Nokian Vatiiva's, K&N air filter(after sucking the old one inside out in a rain storm), waiting for Thorely's and Helwig
  #9 (permalink)
Old 07-04-2009, 07:43 PM
The delay feature for the radio works just like it is suppose to...no problems there. The rear hatch has been well-cleaned and I know it works properly because the "Door Ajar" light comes on and off when it is opened and closed.
Thanks for the suggestions, but I think this one has everyone stumped!
__________________
Virg
1989 Shelby CSX/VNT
Tags
ajar , door , excursion , ford , lights , running , stay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
