Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 02:52 PM
bozzzz94 bozzzz94 is offline
bozzzz94 is starting off with a positive reputation.
Comp. won't come on?
1993 3.0 ltr shorty Aerostar. I checked the 20 amp fuse-good
I noticed the 2 wired low press switch had bare wire exposed-changed it-no power
Switch might be bad so I put clip in connector to bypass-still nothing
I could see the compressor-clutch won't engage to accept freon
What do you think the problem is? Large fuses were changed on drivers fender behind battery-still nothing
Could it be as easy as the clutch being changed and the system coming to life?
Any help would be appreciated-Boz
__________________
1994 Extended Black Sport 4.0 2 wheel drive
1994 Extended Blue/gold 4.0 Eddie Bauer 4 whl-drive
1993 Extended Blue/gold 4.0 Eddie Bauer 4 whl-drive
1992 Shorty Blue 3.0 2 wheel drive
+1989 Extended Red 3.0 2 wheel drive
="5ive" Aerostar's P-R-I-C-E-L-E-S-S signed B O Z
  #2 (permalink)
Old 06-27-2009, 03:07 PM
Forgot to add. Bought the van-sight unseen 3 months ago so I don't know what caused the air not to work or how long it has been since it has worked. I just read about clutch removal on here. Any ideas?--Thanx Boz
__________________
  #3 (permalink)
Old 06-27-2009, 10:19 PM
tboss619 tboss619 is offline
tboss619 is starting off with a positive reputation.
you need to get a 12v test lite and probe the wires going to the clutch and see if you are getting power to the clutch if not then its proberly the pressure switch is bad or it has loose wires ,,,, if your getting power to the clutch then its not engaging properly,,, try takin a small hammer and tap the front of the clutch while the unit is on and engine running if it engages then the clutch needs to be adjusted.....
  #4 (permalink)
Old 06-28-2009, 02:17 AM
xlt4wd90 xlt4wd90 is online now
xlt4wd90 is starting off with a positive reputation.
There is also a relay behind the battery that controls the AC clutch. It's under a black plastic hood that hides 2 or 3 other relays. This one is controlled by the EEC to disable the AC under WOT. It's not likely to be bad, but it's one more thing to check.
  #5 (permalink)
Old 06-28-2009, 03:34 AM
jubangy jubangy is offline
jubangy is starting off with a positive reputation.
You said the compressor clutch won't engage to accept freon...could you give alittle more detail about this because usually it can take a few minutes with the can of "freon" or 134a hooked up to build up enough pressure to engage the clutch, and when it does it may cycle on and off somewhat quickly until it starts to build pressure.
  #6 (permalink)
Old 06-28-2009, 11:02 AM
cookkd cookkd is offline
cookkd is starting off with a positive reputation.
Quote:
He said he bypassed the switch....that should kick in the comp.
__________________
"Alcohol, Tobacco & Firearms should be a Convenience Store and NOT a Government Agency!"
  #7 (permalink)
Old 06-30-2009, 01:26 PM
lsrx101 lsrx101 is offline
lsrx101 has a good reputation on FTE. lsrx101 has a good reputation on FTE.
Bypass the cycling switch and tap the face of the clutch. It's free and takes 30 seconds.
If the clutch engages, the clutch gap needs to be adjusted.
If not, you'll have to dig a bit deeper.
DON'T try to add refrigerant unless you know it actually needs it! Why is it that the first thing people do when their AC doesn't work is grab a can of refrigerant? That's like adding fluid to a slipping trans without even checking the dipstick first.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
