Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 02:51 PM
bozzzz94 bozzzz94 is offline
bozzzz94 is starting off with a positive reputation.
Comp. won't come on
1993 3.0 ltr shorty Aerostar. I checked the 20 amp fuse-good
I noticed the 2 wired low press switch had bare wire exposed-changed it-no power
Switch might be bad so I put clip in connector to bypass-still nothing
I could see the compressor-clutch won't engage to accept freon
What do you think the problem is? Large fuses were changed on drivers fender behind battery-still nothing
Could it be as easy as the clutch being changed and the system coming to life?
Any help would be appreciated-Boz
__________________
1994 Extended Black Sport 4.0 2 wheel drive
1994 Extended Blue/gold 4.0 Eddie Bauer 4 whl-drive
1993 Extended Blue/gold 4.0 Eddie Bauer 4 whl-drive
1992 Shorty Blue 3.0 2 wheel drive
+1989 Extended Red 3.0 2 wheel drive
="5ive" Aerostar's P-R-I-C-E-L-E-S-S signed B O Z
  #2 (permalink)
Old 06-27-2009, 05:20 PM
2000Ford2000's Avatar
2000Ford2000 2000Ford2000 is offline
2000Ford2000 is starting off with a positive reputation.
Initially, using a long tool and whack on the front of the clutch when it's supposed to be engaged. I just had a 99 F-150 2 days ago that I found was the clutch. First thing I always do if pressures are good, or in your case, the low pressure switch jumped out. It needs a pretty good whack. I used a long, large screwdriver and hit it increasing harder.
__________________
2000 E-150 Jayco Conversion (5.4)
1989 E-150 Conversion (5.0)
-previous Fords
1989 E-150 Trans-Aire (5.0)
1988 E-350 26' Jayco RV (7.5)
B.C. (Before Children)
1991 Escort (1.9)
1982 Capri (2.3)
1971 Pinto (2.0)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
