Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #2431 (permalink)
Old 10-19-2009, 04:51 PM
95_Dually's Avatar
95_Dually 95_Dually is offline
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE. 95_Dually is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Krewat View Post
How many production aluminum-headed 302/351W's?
Maybe I should have been more specific, but I was comparing the modulars to other aluminum-head motors. Not iron-head production slugs
GM doesn't have a problem. Dodge, Toyota, Honda and the list goes on, don't have problems. The new V-10 doesn't shoot out plugs either. Sounds like VW and 2v V-10 are related somehow.
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v
2000 Ranger 4X4 No MODS, yet!
  #2432 (permalink)
Old 10-19-2009, 04:52 PM
phillips91 phillips91 is online now
phillips91 is gaining momentum as a positive member of FTE.
I was comparing the modulars to every ford small block v8 from 1962 until 1996/97. That's 35 years of trouble free spark plugs. What's the modular on now, 13 years(with some limited production starting in 91)? 9 years that couldn't keep the plugs in and 4 years you can't get the plugs out?
They haven't been production, but I've owned several aluminum headed mustangs and have yet to blow a plug out of them. The other brands haven't had any problems with their aluminum heads either. So it must not be the aluminum that's causing the problem. It's probably the combination of the aluminum and the lack of threads. Or in other words, a design flaw
  #2433 (permalink)
Old 10-19-2009, 04:54 PM
95_Dually's Avatar
1995 Ford F-350
But that is in the past. Now we move on to newer smog laws and restrictions. Yippee
__________________
Sam
  #2434 (permalink)
Old 10-19-2009, 04:55 PM
It's quitting time for me guys. You all have a good evening and don't beat on each other too badly while I'm gone
  #2435 (permalink)
Old 10-19-2009, 04:57 PM
95_Dually's Avatar
1995 Ford F-350
Awe man, now I have nothing to do.
__________________
Sam
  #2436 (permalink)
Old 10-19-2009, 04:58 PM
95_Dually's Avatar
1995 Ford F-350
That's ok. I ran out of popcorn!
__________________
Sam
  #2437 (permalink)
Old 10-19-2009, 05:10 PM
ken kenmnedy's Avatar
ken kenmnedy ken kenmnedy is offline
2003 Ford F-250
ken kenmnedy is starting off with a positive reputation.
OK boys its all as easy as this...... a superduty is a superduty is a superduty.....gas or oil v8 or v10 they all get it done!!!!!!!
__________________
03,f250,sc,sb,xlt,RED,5.4,4x4,4:10LS,western 7.5 ultramount and just a touch of hypertech wifes gotta 03 sport trac xlt with all the bells
  #2438 (permalink)
Old 10-19-2009, 05:52 PM
95_Dually's Avatar
1995 Ford F-350
What he said
__________________
Sam
  #2439 (permalink)
Old 10-19-2009, 06:28 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Quote:
Using the logic of previous posters in this thread, there would be no spark plug insert kits available if there wasn't a problem.
Look up Timesert, they have kits for BMW, Chevy (including the LS motors), Toyota and Honda ++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair, I suspect Dodge can use a standard generic insert.
I was using a VW tech's experiences as an example of how other manufacturers also have spark plug problems. They do exist.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #2440 (permalink)
Old 10-19-2009, 07:29 PM
95_Dually's Avatar
1995 Ford F-350
Thread inserts were developed a long time ago and are also used in cast iron heads. Sometimes mechanics screw up and cause problems like this. Thread inserts or helicoil's are used in many areas not just on spark plug holes.
This is pretty funny how the factory heads blowing sparkplugs and people stripping or cross threading bolts or sparkplugs are the same issue. I don't know.............
EDIT: I have not heard of any other motor launching sparkplugs except for VW which I just learned today.LOL
__________________
Sam
  #2441 (permalink)
Old 10-19-2009, 08:29 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
Like it was mentioned, blowing plugs is not a characteristic of aluminum heads, its a characteristic of poorly designed aluminum heads.
Virtually every small engine since the mid 50s has had aluminum heads, and I don't hear about them blowing sparkplugs out. I've seen lawnmowers with less-then-finger-tight sparkplugs still running happily and no sign of the threads being stripped out. All of the new fancy OHV V-Twin small engines running 9:1 compression don't eject plugs. I don't see tons of dirt-bikes, four wheelers and motor cycles shooting plugs either. My Honda XR200 has about 12 "threads" on both the plug and the head to hold it in, the original 2 valves had what? 4-5?
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #2442 (permalink)
Old 10-19-2009, 09:49 PM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
Man after reading the last couple of pages I sure am glad I don't have spark plugs!!LOL!
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #2443 (permalink)
Old 10-19-2009, 11:13 PM
95_Dually's Avatar
1995 Ford F-350
Quote:
Originally Posted by mudmaker View Post
man after reading the last couple of pages i sure am glad i don't have spark plugs!!lol!
rofl!
  #2444 (permalink)
Old 10-20-2009, 09:03 AM
No one is saying that no other car on the road besides the triton has ever blown a plug. Sometimes people who should never even open the hood of their vehicle try to change plugs and cross thread them, don't tighten them good enough, etc, and they blow a plug. I said the modular is just MORE PRONE to shooting plugs and that even factory trained technicians have problems getting the plugs in correctly(if the plug shooting is caused by improper installation). Go to the modular forum and look up blown spark plugs and see what you get. Dozens of threads with hundreds of people complaining about it happening to them. Go to yahoo and a search for blown plugs. 9 out of 10 sites that come up are about the modular. Consumer affairs has over 300 pages of people saying it happened to them. You can search the entire forum here and you won't find as many blown plugs in every group combined as you'll fine in ONE thread in the modular forum alone.
In the 4.6/5.4 section someone posted a poll wanting to know how many have had a plug blow out. 52 of the 159(32%) people responding said they have had it happen, and that was just 4.6 and 5.4 owners and didn't count multiple blown plugs. That's a very high percentage for that many of voters. Some of those people have had 3 or 4 plugs shoot out on the same engine. It's not something that's going to happen to every single engine or anything, but it is something that happens at a much higher frequency than on other engines.
  #2445 (permalink)
Old 10-20-2009, 09:10 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
2005 Ford F-250
Johnny Langton has a good reputation on FTE. Johnny Langton has a good reputation on FTE.
The same can be said about the 6.0L and head gaskets,yet the diesel guys all argue that it's not a problem,and it's isolated to certain years,etc.
JL
__________________
1997 Thunderbird LX 4.6L/4R70W
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab
3V V10/Torqshift 4.10LS
2001 Navigator
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
Tags
184k , 2004 , 73 , chum , diesel , engine , excursion , f350 , ford , mileage , miles , motor , psd , triton , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
