Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #226 (permalink)
Old 07-03-2009, 12:26 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
2005 Ford F-250
Johnny Langton has a good reputation on FTE. Johnny Langton has a good reputation on FTE.
Quote:
Originally Posted by mudmaker View Post
I dont know how much boost they are creating here, but here is something I found for V10's.
http://image.sporttruck.com/f/914933...mage_large.jpg
Keep in mind these are dyno numbers, not on paper out a brochure
Edit: just found it has 22 psi of boost and it cost $5-6k
A centrifugal on a 2V.
I'm not talking about a centrifugal S/C.
JL
__________________
1997 Thunderbird LX 4.6L/4R70W
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab
3V V10/Torqshift 4.10LS
2001 Navigator
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
  #227 (permalink)
Old 07-03-2009, 07:01 PM
QwkTrip QwkTrip is offline
QwkTrip is gaining momentum as a positive member of FTE.
Putting that much boost into a stock gas engine will melt down the pistons and spew oil out every orifice that is connected to the oil sump chamber. I thought this would be obvious but apparently it is not.
A centrifugal supercharger enhances power mostly at high engine speeds. That's fine for a drag racer with a loose torque converter but not very suitable for a working truck. I'd focus on a turbocharger or positive displacement supercharger for a truck application. A turbocharged V10 would be a monster and fairly inexpensive if you fabbed up your own exhaust. Again, you would really have to be careful if you wanted to tow under boost.
  #228 (permalink)
Old 07-03-2009, 07:12 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Gee, how did I miss this one
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #229 (permalink)
Old 07-03-2009, 07:19 PM
dkf's Avatar
dkf dkf is online now
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
The highest boost Supercharger system Vortech ever made for the V10 used a max of 9psi of boost. They were designed to be used with a stock engine.
http://www.vortechsuperchargers.com/...on.php?pvk=624
Heres a link to prove your numbers are way off. A bolt on supercharger kit was never made for the V10 that put out more than 9 pounds of boost. Of course all the bolt on kits were also for the 2V only, the 3V would put out more power.
  #230 (permalink)
Old 07-03-2009, 07:20 PM
Quote:
Probably because 50% of this thread is filled with people pretending they're not interested yet filling the pages with the same comment that they want a beer over... and over... and over... and over... and over again.
  #231 (permalink)
Old 07-03-2009, 10:29 PM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
Your right my numbers are way off! That kit is almost $7K!!!!
I was looking at the spec sheet that listed max boost at 22 for the heavy duty unit.
Here is the page I looked at.
http://www.vortechsuperchargers.com/scspecsheet.php
They must limit the boost on the motor to keep it from blowing the spark plugs through the hood!
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #232 (permalink)
Old 07-03-2009, 10:39 PM
Crazy001's Avatar
Crazy001 Crazy001 is offline
2008 Ford F-250
Crazy001 has a good reputation on FTE. Crazy001 has a good reputation on FTE.
Hrmm...
8 cylinders + 2 turbos = 10
__________________
Tom,
Current truck - 2008 F250 CC 4x4 PSD
Previous Fords:
2007 F150 Screw 4x4
2003 F150 4x4 r/c auto
  #233 (permalink)
Old 07-03-2009, 10:48 PM
mudmaker's Avatar
2002 Ford F-350
You know I was just thinking about that $7k supercharger. If take and add that to a brand new V10 and compare it to a 6.4 with an exhaust and tuner I dont think it would even be a close contest on a dyno. Aren't the 6.4s getting close to 500hp with just a tune and exhaust in some cases?
The cost of the the mods to the V10 and the 6.4 would be about equal when you add the cost of the 6.4 option to a new pickup.
__________________
Marc
  #234 (permalink)
Old 07-03-2009, 11:30 PM
Pinky Demon Pinky Demon is offline
Pinky Demon is starting off with a positive reputation.
Quote:
Originally Posted by bigrigfixer View Post
So using that logic, why not pull the turbo off the diesel, and pull 2 spark plugs out of the V10? And no, I don't mean just run a 5.4, I mean run the 6.8 with 8 spark plugs.
Do you understand what a joke is?
__________________
2002 F-250 - V10, Crew Cab, Short Bed, Lariat 4x4 aka My Lovely Big Girl.
Click HERE for my full review w/ pictures of the Banks Powerpack Exhaust System.
  #235 (permalink)
Old 07-04-2009, 01:06 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is online now
2004 Ford Excursion
My Garage
weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE.
Are will still talking about how diesels are better then gas?
__________________
Nick PAA#9
08 F-450 K R 6.4 SPARTINIZED, DPF/CAT GONE, RR Boots
04 X 6.0, 08 towing mirrors, 15k hitch, Firestone air bags
01 X 7.3, TN BB turbo, Dp tuner, ITP RR, RR up pipes, 4 Dipricol gauges,MBRP 4inch, 6637,650 dash with 2 auto meeter gauges, RR boots,
95 F-250 7.3, 6637
  #236 (permalink)
Old 07-04-2009, 12:08 PM
Krewat's Avatar
Quote:
Nope, it's become a contest to see who can urinate further
__________________
  #237 (permalink)
Old 07-04-2009, 01:18 PM
CampSpringsJohn CampSpringsJohn is online now
CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold
He with the biggest hose will win that contest! That leaves me out!
__________________
1997 Super Duty, PSD,6637, high idle, 50hp, & 80hp. 150cc injectors.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, high idle, 50, 75 tow, 100, 120, & 140, HPX Crossover
Kentucky Chapter Member
  #238 (permalink)
Old 07-04-2009, 01:51 PM
bill11012's Avatar
bill11012 bill11012 is online now
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by superduty4x4 View Post
I feel like stirring the pot. That said...
I find it amusing that the V10 needs 10 cylinders to get done what a diesel can do with 8.
The 6.4 takes two turbos to do what the v10 can do with none!
__________________
My V10 will out pull your PSD any day of the week.*
*If you have a stock 7.3 with 3.73s or 3.55s and 4 speed auto. Test must be at sea level
I will smoke the 6.0,6.4 and new 6.7 after I do the twin turbo mod.
  #239 (permalink)
Old 07-04-2009, 01:52 PM
bill11012's Avatar
no, we are talking about how gas is better.
__________________
  #240 (permalink)
Old 07-04-2009, 02:08 PM
jdadamsjr jdadamsjr is online now
jdadamsjr is gaining momentum as a positive member of FTE. jdadamsjr is gaining momentum as a positive member of FTE.
Quote:
And no one has proven that
nor taken me up on my offer to prove that
nor even DEFINED "better"
and lastly at what ?
(u can't be all wrong though !!!! I sold my restored 'Datsun' 280zx 2+2 turbo a few years back to my mail man !!!! he said he had seen it each day in the back by the pool and always wanted it FUN little car !!!)
(he wanted a package deal with the wife too, but not a fair price - I didn't have enough cash!)
__________________
05 Ex 4x4 6L - GOS lite Harness,Hellwig, Walker BTM, SCT is all - 8.9 @ 75 1/8th!
http://video.thedieselgarage.com/Pla...ker&p=0:thumbs
Gone but not forgotten -2003 Ebony Ex, 4x4 6L Westin Bull Bar, PIAA 520's, PIAA Headlamp Upgrade Turbo-back Exhaust, LOADED...
even goner-2002 4x2 7.3L Ex Limited
Tags
184k , 2004 , 73 , chum , diesel , engine , excursion , f350 , ford , mileage , miles , motor , psd , triton , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
