Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #181 (permalink)
Old 07-01-2009, 04:50 PM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
Springfield Armory
indyF-350psd is gaining momentum as a positive member of FTE. indyF-350psd is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Johnny Langton View Post
Yeah,and it's also limited on how much boost it receives from the turbo when it's stock.
JL
you seem real concerned about the turbo!
  #182 (permalink)
Old 07-01-2009, 05:07 PM
Ace!'s Avatar
Ace! Ace! is offline
Ace! is gaining momentum as a positive member of FTE. Ace! is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by preppypyro View Post
Why they dont do the comparisons like single rear axle with lowest ratio, or highest ratio (point is being the same body style, with the highest or lowest factory optioned ratio) makes the test laughable.
Compare the 3.73's in a SRW diesel, to the 4:10 in the SRW v10. Or go the other way, compare the the 4:30 to the 4:30 (lowest gear ratio offered by both trucks from stock)
Someone probably pointed this out, but the 2008 (as in the article) are available with 3.55 or 3.73 for the diesel and 4.10 or 4.30 for the V10. 3.55 is standard with the diesel and 3.73 is optional; speaking of SRW trucks only.
__________________
2005 F250 V10, CC, SB, 4x4, 4.30 axle ratio
1994 Exploder XLT, 4x4, auto trans and Pioneer cd player
"Deserve's got nothing to do with it"
  #183 (permalink)
Old 07-01-2009, 05:11 PM
Ace!'s Avatar
If someone wants to drive my truck, they certainly can. If they can tell stuff by the seat of the pants more power to them. I figure the speed limit with a trailer is 55mph where I live and I can pull any pass around here at 55mph, so it doesn't really make too much difference. I guess if your truck, with whatever engine, can get up to 55mph faster than mine you can crack me open a beer when you get to camp, cause I'll only be seconds behind you.
BTW, I live in a valley, at the bottom of the highest pass on Interstate 5 and I can maintain 55mph up or down it, both ways, in the snow.
__________________
  #184 (permalink)
Old 07-01-2009, 05:17 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of
It is not how fast you can get to 55, it's if you can maintain 55 on the hills. Most places I drive the speed limit is 70. That is the real test. lol.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-VB, DP-TUNER LIVE- stock, HI. 40t, 60t, decel, 80t, 80e, 140s, OBA, 203*, billet housing, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #185 (permalink)
Old 07-01-2009, 05:44 PM
Ace!'s Avatar
Well, based on my post you can see I can maintain 55mph pulling a trailer; although it doesn't mean I'm driving 55mph, and it doesn't make any difference what truck you're driving. That was the point of my post, I can maintain the speed, and live in a valley nearest the highest pass on the Interstate. I can maintain a faster speed pulling the trailer too, it's just a matter of how much I want to push the acclerator. If there's something significantly more important than that, I don't know. Maybe the differences between the trucks become more apparent at the drag strip, but I don't go there, I go camping and I get to the campground at the same time as anyone else, and my truck doesn't struggle doing it.
__________________
  #186 (permalink)
Old 07-01-2009, 05:45 PM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
That is not true. 3.55 is an option along with 4.10 and 4.30 on the diesel, the 3.73 is std
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #187 (permalink)
Old 07-01-2009, 05:47 PM
Ace!'s Avatar
Quote:
Not on the SRW, which is what the person I was quoting was saying. 4.10 and 4.30 are only available on the gasser(s) when discussing SRW. 3.55 is standard and 3.73 is optional on the SRW diesel.
__________________
  #188 (permalink)
Old 07-01-2009, 05:51 PM
mudmaker's Avatar
2002 Ford F-350
I priced 08's when they came out and a F350 SRW had std 3.73. 3.55 and 4.10 were options I know for sure because I was ask specifically if I wanted either one of those instead of the std. IIRC the 4.30 is only available on DRW, which makes since as you would probably be putting so much power to the ground that you would light the tires up to easily!
__________________
Marc
  #189 (permalink)
Old 07-01-2009, 05:54 PM
Ace!'s Avatar
4.10 and 4.30 are only available with the dually. Only the single-rear-wheel gassers have 4.10 and 4.30. Maybe it's time to price another truck
One thing though, I didn't realize, standard ratios are different for the different transmissions. The SRW diesel has 3.73 standard with the manual transmission and 3.55 standard with the auto transmission.
__________________
  #190 (permalink)
Old 07-01-2009, 06:07 PM
mudmaker's Avatar
2002 Ford F-350
Just checked the ford website and you are right about the 4.10 and 4.30's now, but is still puts 3.73 as std.
__________________
Marc
  #191 (permalink)
Old 07-01-2009, 06:10 PM
Ace!'s Avatar
3.73 for the manual transmission
3.55 with the automatic transmission
__________________
  #192 (permalink)
Old 07-01-2009, 06:11 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old and mean
1993 Ford F-250
Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold
Quote:
Originally Posted by cpdorroh View Post
I figured we'd be running low on beer, so I brought some more. Help yourselves. This has gotten pretty good.
You better get ready to make another beer run!
__________________
FORCE IT!,IF IT BREAKS IT NEEDED REPLACED ANYWAY!
IF IT CANT BE FIXED WITH A HAMMER, ITS A ELECTRICAL PROBLEM!
Still bitterly clinging to guns and religion.
Dave
Oregon Assistant Chapter Leader: To join the Oregon Chapter, click HERE
  #193 (permalink)
Old 07-01-2009, 06:13 PM
mudmaker's Avatar
2002 Ford F-350
3.73 is also std when you go 4x4
__________________
Marc
  #194 (permalink)
Old 07-01-2009, 06:24 PM
Ace!'s Avatar
Well, you learn something new everyday. Thanks.
__________________
  #195 (permalink)
Old 07-01-2009, 06:39 PM
This is the reason we need to have this broke up into sections. I can sit here and say that the 4.10 is standard and be true. It is standard on my truck. We keep talking about different trucks while I am only talking about the 7.3. Very confusing.
__________________
RICK, PAA MEMBER #4
Tags
184k , 2004 , 73 , chum , diesel , engine , excursion , f350 , ford , mileage , miles , motor , psd , triton , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
