Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1726 (permalink)
Old 09-18-2009, 10:51 AM
Smokin''s Avatar
Smokin' Smokin' is offline
Smith & Wesson
1999 Ford F-250
Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of
Quote:
Originally Posted by bill11012 View Post
and turbo and glow plugs and all the things a V10 does not need....
but we are taking about horses, right?
My horse has never had problems with its turbo.
And glow plugs? Kinda like spark plugs, right?
I've changed my glow plugs once, and it was only about 10,000 miles ago.
What else ya got?
__________________
Lisa Early '99 PSD long bed XLT supercab. 4" Pro Comp suspension lift, 315 BFG AT's on 17" Liquid Metal Gatlins, Hypermax Boost Pyrometer, 4" exhaust, DP Tunes - no start, 60 Tow, 80 Econo, 120 Race, 203* thermostat and billet housing, 6637 w/Pete's cover, CCV, oil crossover Kit.
  #1727 (permalink)
Old 09-18-2009, 11:02 AM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
What else ya got?
well, you have a 7.3 so i cant say much.
They are great motors.
when My dad bought this truck, It took us 6 weeks to decide if we wanted the 7.3 or V10.
We went with the V10 and have always been happy we did, but If I had gotten the 7.3, I am sure I would love it to. It would just need mods to be as fast as a stock V10...
__________________
My V10 will out pull your PSD any day of the week.*
*If you have a stock 7.3 with 3.73s or 3.55s and 4 speed auto. Test must be at sea level
I will smoke the 6.0,6.4 and new 6.7 after I do the twin turbo mod.
  #1728 (permalink)
Old 09-18-2009, 11:04 AM
KelVarnson KelVarnson is offline
KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE.
Quote:
Originally Posted by Quick444 View Post
So if they aren't towing more or faster, how do they tow better?
Others beat me to it. Lower RPM, better fuel economy, less noise, less wear. The same reason a stock 7.3 might be more comfortable to tow with than a V10, even though the V10 should pull more.
Quote:
Originally Posted by preppypyro View Post
Ill admit im not an expert on the subject, but Ive read up on it to the point where I get the basics of it. Where I get cloudy, is when I think of a 500 high horsepower civc engine installed in a superduty truck, and saying to myself yep, that would outpull a v10 or a 7.3.
It's all about the gears. It's possible. But if it were practical and desirable, they would be doing it, and they're not.
Yes a semi truck is larger so it needs more torque to get moving, but semis now a days have the same rear diff ratios as our pickups, and the amount of gears they have just gets the load going a little faster, yet they haul 50k plus, and drive the same roads we do while doing it.
...and slow WAY down on the hills, because their horsepower to weight ratio is vastly disproportionate to our pickup trucks. That 400-ish HP is enough to overcome rolling resistance and wind resistance, and small hills, and keep them rolling at freeway speeds. But as soon as they come to a serious incline, they have to slow way down and drop gears. 400 HP will only do "so much" work. On a hill, the work changes from a low-drag/high speed situation to a high drag/low speed situation. And since power = force x speed, power is ultimately the limiting factor.
So why does the torque in a semi double (sometimes triple) the amount of horsepower it has?
It does not. You can NEVER have more horsepower at the rear wheels than you have at the engine. That is physically impossible.
Quote:
Originally Posted by phillips91 View Post
thats a nice engine, but the v10 will still outpull it.
Heh heh....
__________________
'02 F250 SCLB 7.3 4WD, 105k. 6637 Filter, JW Valve Body, 6.0 Trans Cooler, 285/75 16 Michelin LTX-AT2's, Line-X, Snug-Top Shell, Yakima Racks.
  #1729 (permalink)
Old 09-18-2009, 11:14 AM
sideshow's Avatar
sideshow sideshow is offline
sideshow is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by KelVarnson View Post
. Look it up. It's not going to sink in for you until you understand the actual meaning of horsepower.
I think somebody actually needs to look up the definition of WORK. Force applied across a distance. W = F x d . For a given distance (d) the C9 can apply more force (F) which will ALWAYS equal more WORK (W).
Edit to add. I misread the post earlier. I READ Cat C9 but had in my head "D9". I thought we were arguing the ability of the V10 to out work a D9 dozer. DOH!!
__________________
2002 F250 CC SB 4x4 - 6637, Zoodad, AIH delete, WW, non EBPV pedestal, CCV, 6.0 Trans Cooler, OBA, 5" cannon, DiPricol Optix's, Coolant filter, In-tanks, Rotella ELC, 315/75/R16 Toyo MT's, Eagle Alloys 137s, Yellow Top Optimas
______________________________________________
Kevin
  #1730 (permalink)
Old 09-18-2009, 11:26 AM
clux's Avatar
clux clux is online now
ain't wrapped tight
clux has a brilliant future clux has a brilliant future clux has a brilliant future clux has a brilliant future clux has a brilliant future clux has a brilliant future clux has a brilliant future clux has a brilliant future clux has a brilliant future clux has a brilliant future clux has a brilliant future
Quote:
Well, now that you mention it, of course a V-10 superduty can outwork a d-9.
With a blade added to it, and of course the proper gearing, it's a catskinner's dream, it'll work circles around a puny D-9.
__________________
2000 F350 cc lariat 4wd 7.3l
1991 Bronco xlt 5.8l
known 6637 basher
known OT basher
known signature basher
  #1731 (permalink)
You're leaving out time. A higher horsepower engine will do the same work faster.
__________________
  #1732 (permalink)
Old 09-18-2009, 11:36 AM
phillips91 phillips91 is offline
phillips91 is gaining momentum as a positive member of FTE.
i think you misread what he was asking. he wasnt saying you can have triple the hp at the wheels as you do at the engine. he was saying that the torque on big rigs is usually 3 times higher than the hp(400 hp and 1200 tq). the answer to that is because they are pretty much all goverened around 2200 rpm.
  #1733 (permalink)
Old 09-18-2009, 11:37 AM
Rush117 Rush117 is online now
Rush117 is gaining momentum as a positive member of FTE.
I like story time.
I still don't see how Krewat is considered a "whiner"? Is it because he needed more expensive oats?
I guess whiner wasn't the right word. He brays louder. He's perfectly happy eating the scraps left over after they make Bill's food. Unfortunately they don't have a lot of scraps left over and the demand for the scraps is very high. People even heat their homes in the northeast with the scraps so Krewats food bill does sometimes exceed Bills. Luckily, Krewat doesn't eat as much. Bill has to stop and eat just about every time he passes food.
  #1734 (permalink)
Old 09-18-2009, 11:46 AM
sideshow's Avatar
yeah I left out time there, but I was still thinking about a dozer. I had in my head that if you couldn't even apply enough force to move the object (like a huge load of rocks) that you couldn't actually perform any work, and time would be irrelevant.
In all reality power and work are not that simple. Horsepower is a product of torque and rpm/5252. so torque comes into play as well. You are correct that given the same torque, a higher horsepower engine will do more work for a given time.
It isn't just about horsepower though.
Also since we're talking about work and time I thought I'd add the following. I believe the lower RPM's the diesel operates at, yields itself to a longer lifetime of work. Meaning, that I think a lifetime of work at 2500 rpms would be less stressful on a diesel than a lifetime of work at 4500 rpms. I know that there are some high mileage v10s out there, but I truly believe them to be the exceptions and not the rule. I'm not stating that as a fact, just my honest opinion.
I seriously considered buying one at first, but I spoke to numerous contractors working for the same company(ies) I do work with, and they all complained about fuel mileage. None of them got more than 10 mpg when towing or with a loaded truckbed. Seeing that I'm usually towing (3500-7500lbs) daily, I was turned off by the fuel mileage. That was before I found FTE though, and I had no prior knowledge of either engine. I chose the diesel for the simple fact that 9 out of 10 work trucks I saw were diesel, with the overwhelming majority being Fords.
I'm happy with my choice, and I enjoy the fact that I can be towing 12k at 2500rpm +/- with OD off, and still have plenty of pedal left to pass the occasional (more like frequent) gray hairs on the road. One thing that did strike me as interesting is when I was searching for my truck (2005), I couldn't even find a used one with less than 100k for under 30,000. NO WHERE. I know 100k isn't alot of miles, for this engine, but at that time I wanted one with some warranty left. I ended up finding mine with 54k, and talked them down to 25,000. There were plenty of v10's for sale at that time, and most were about 5,000 less. The higer resale price was an added bonus, even though I plan on keeping this truck forever.
__________________
Kevin
  #1735 (permalink)
i know how we can settle this once and for all..... i have an international big rig wrecker that has a cummins 8.3 with 400 hp and 1250 tq. we can hook a v10 with 400 hp to it and have a pull off. ill start out in the appropriate gear so that our final drive ratio will be the same. heck, ill even put it in neutral and let you pull me in 1st gear until you get to 3k rpm before i get on it. youll have a rolling start, gearing advantage AND be in your prime power band before i even let the clutch out. any takers? im sure it will make one heck of a video
  #1736 (permalink)
Old 09-18-2009, 11:47 AM
95_Dually's Avatar
95_Dually 95_Dually is offline
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE. 95_Dually is gaining momentum as a positive member of FTE.
So what is the verdict. After all of the education we have received regarding HP and Torque. Which truck is the better truck.
Wow, that is a loaded question, huh?
I think both truck/engine combos are good. It all depends on personal preference. I think the V10 in STOCK form has better performance. But once the PSD is SETUP, the V10 doesn't stand a chance.
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v
2000 Ranger 4X4 No MODS, yet!
  #1737 (permalink)
Old 09-18-2009, 11:49 AM
bill11012's Avatar
Quote:
I do not have to gas up that much.... I can go over 300 miles on my 36 gallon tank.
__________________
  #1738 (permalink)
Old 09-18-2009, 11:50 AM
95_Dually's Avatar
1995 Ford F-350
ROFL. You are so funny. I like simple stories.
__________________
Sam
  #1739 (permalink)
Old 09-18-2009, 11:54 AM
Smokin''s Avatar
Smith & Wesson
1999 Ford F-250
You are too funny man.
I still would rather have a clydesdale than a quarter horse.
Personal preference I suppose.
I have squeezed about 600 miles out of a single tank.
Consider also that I usually stop at about 1/4 tank for fillups to avoid running out of fuel. I also have a lift, and performance mods.
__________________
  #1740 (permalink)
Old 09-18-2009, 11:55 AM
youve been driving that 460 too long if you think thats good gas mileage lol. by my calculations that is only 8.3 mpg. 300/36=8.33. with my old 7.3 i can go 800 miles on a 40 gallon tank. granted, it does get a lot better mileage than the 6.0 and 6.4. but this is v10 vs psd, not v10 vs 6.0 and 6.4.
Tags
184k , 2004 , 73 , chum , diesel , engine , excursion , f350 , ford , mileage , miles , motor , psd , triton , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
