Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #136 (permalink)
Old 07-01-2009, 12:47 PM
silly34 silly34 is offline
2004 Ford F-250
silly34 is starting off with a positive reputation.
I bought my PSD because I just like the sound of diesels and the turbo spooling. Oh and it was white.
__________________
2004 F250 King Ranch 4WD 6.0L SRW
4" MBRP Exhaust, Bilsteins, SCT X3 with Innovative Diesels Extreme Street tune
ΜΟΛΩΝ ΛΑΒΕ
  #137 (permalink)
Old 07-01-2009, 12:56 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1999 Ford F-250
superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold
Quote:
Originally Posted by Johnny Langton View Post
Anyone that distrusts test results conducted at Ford's own proving grounds with timing lights, measured distances, and known weight loads, etc is beyond ignorant.
JL
I couldn't care less what a truck does over a measured distance or against a timing light. I want to know how it works on the road with my arse in the seat. Aside from that, how was that test run- did they make multiple runs? How was each truck equipped (cab config, gearing, etc)?
If you want to trust those test results for a 6.4 vs. 6.8 then suit yourself. How about some results of a 6.0 vs. 6.8 and a 7.3 vs. 6.8? And please provide a link to the article if you would (I didn't see one in this thread, just cut/paste text).
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
  #138 (permalink)
Old 07-01-2009, 01:00 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
2005 Ford F-250
Johnny Langton has a good reputation on FTE. Johnny Langton has a good reputation on FTE.
RTFA.
http://www.pickuptrucks.com/html/200...shootout1.html
__________________
1997 Thunderbird LX 4.6L/4R70W
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab
3V V10/Torqshift 4.10LS
2001 Navigator
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
  #139 (permalink)
Old 07-01-2009, 01:01 PM
CampSpringsJohn CampSpringsJohn is online now
CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold
JL
To expand on what Chase was saying, do the testers of these trucks drive trucks every day? If so, what kind of driving do they do? Do they drive them like a car, or do they work them. A truck that one might use for going to work and the store may be quite different than one used to haul trailers accross the country loaded.
What would every day drivers say about the different trucks?
Edit: Chase already answered the question.
__________________
1997 Super Duty, PSD,6637, high idle, 50hp, & 80hp. 150cc injectors.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, high idle, 50, 75 tow, 100, 120, & 140, HPX Crossover
Kentucky Chapter Member
  #140 (permalink)
Old 07-01-2009, 01:03 PM
2005 Ford F-250
See my last post.
RTFA.
JL
__________________
12.16@111.78
2005 F250 Crewcab
2001 Navigator
  #141 (permalink)
Old 07-01-2009, 01:11 PM
See my last post.
RTFA.
JL
Yep, I saw that. Based off that report, it boils down to what you personally like. They are very close in the drags, both loaded and empty, think the gas was just a hair quicker on both accounts.
__________________
  #142 (permalink)
Old 07-01-2009, 01:20 PM
1999 Ford F-250
RTFA yourself, and drop the attitude.
Quote:
This page is an opportunity to compare the relative performance of the single rear wheel gas pickups against their dual rear wheel diesel counterparts on the 15% grade.
Obviously, not an apples to apples comparison (primarily because of weight and rear axle and rear track differences between the 3/4-ton and 1-tons), but it provides some indication of the scenarios where each type of engine excels.
Gee... funny that your beloved article states in right up front that this isn't an apples to apples comparison...
The drag strip crap I didn't read, because I could care less what my truck or any other truck does on a drag strip... I want to know how the work IN THE REAL WORLD in REAL APPLICATIONS. And as far as I can tell, the grade testing was done on a road with level grade, no curves. That's all fine and dandy, but I want to see what happens on a real road, where the grade varies and the road turns. Even so I thought it was interesting that on the 7% grade your precious V10 and the 6.4 were basically dead even, and that the V10 edged it out on the 15% grade.
And like I've said several times, I still want to see comparisons on the older gen Ford diesels against a similar vintage V10.
__________________
Chase
PAA Member #2
  #143 (permalink)
Old 07-01-2009, 01:39 PM
MINNESOTALEE MINNESOTALEE is offline
MINNESOTALEE is starting off with a positive reputation.
Hi
FTE reset my counter yesterday. Not sure the reason. Anyway thanks for the encouragement!!! Now I'm up to 2.
Lee H.
  #144 (permalink)
Old 07-01-2009, 01:45 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of
See my last post.
RTFA.
JL
Single wheel 3/4 ton, 4.30 gears V-10
Dually 1 ton, 3.73 gears, diesel.
Good test, yeah, can't get any better apple to apple test then that.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-VB, DP-TUNER LIVE- stock, HI. 40t, 60t, decel, 80t, 80e, 140s, OBA, 203*, billet housing, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #145 (permalink)
Old 07-01-2009, 01:58 PM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
I dont understand why the guys doing the test dont spec the vehicles being used. It is because they probably dont know enough themselves to spec them. They are not even trying to make an apples to apples test. Falling back on just saying what ever the manufacturers gave us is a lame excuse. All the test shows is that you can spec a gas motor with the lowest gear available to pull with a diesel spec'd with the highest gear available. They didnt even match the diesels in the test, the dodge had 4.10's. This is why so many people have said they dont like magazine test.
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #146 (permalink)
Old 07-01-2009, 02:01 PM
2005 Ford F-250
3/4 ton to 1-ton,there's not any mechanical or structural difference in the trucks-period. The blocks under the springs are it.
Dually vs SRW-yeah,there's a slight difference there.
As for the gears-that's how Ford equips them-talk to them about it.
It's as close to real world as you're gonna get.
JL
__________________
12.16@111.78
2005 F250 Crewcab
2001 Navigator
  #147 (permalink)
Old 07-01-2009, 02:06 PM
1999 Ford F-250
Wrong... both trucks have optional gear ratios, at least last I checked they did.
JL
We could easily create a real world test right here on the forums if we can find 2 people with like trucks that live close to each other and are willing to take the time. It would be much more beneficial as a comparison than the magazine test.
__________________
Chase
PAA Member #2
  #148 (permalink)
Old 07-01-2009, 02:14 PM
2005 Ford F-250
4.10 is the standard ratio for the 6.8L trucks,with 4.30 being the only option.
3.73 is the standard for the diesel,with a 4.10 or 4.30 being the option unless you order it an F450, then you can get up to a 4.88.
JL
__________________
12.16@111.78
2005 F250 Crewcab
2001 Navigator
  #149 (permalink)
Old 07-01-2009, 02:15 PM
JL
I guess you don't know how weight, gears, and truck configuration plays into pulling. I don't know what you pull, but I pull more weight then I should at times. I know how to rig a truck for pulling, and 3.73 gears is not a choice I would make on a dually.
EDIT: I didn't have the 3.73 option with my truck, and I bought it brand new.
__________________
RICK, PAA MEMBER #4
  #150 (permalink)
Old 07-01-2009, 02:20 PM
jdadamsjr jdadamsjr is offline
jdadamsjr is gaining momentum as a positive member of FTE. jdadamsjr is gaining momentum as a positive member of FTE.
Heck, I'm no racer, but I'd be willing to 'represent'
at least the HEAVY 6.0 side of the house in our Ex....
I am about 5 miles south of the Kennedale 1/8th mile course and would have been there this weekend for the DR Performance event except for a "prior engagement" ...
will even offer to put u up in our second master bedroom if it's too much of a drive
I have a 5 x 20 trailer we can load up and test that too
This truck ran on that track a few years ago.... haven't been back since, but would be willing just to see if we can get some more sofa racing fear talk going
__________________
05 Ex 4x4 6L - GOS lite Harness,Hellwig, Walker BTM, SCT is all - 8.9 @ 75 1/8th!
http://video.thedieselgarage.com/Pla...ker&p=0:thumbs
Gone but not forgotten -2003 Ebony Ex, 4x4 6L Westin Bull Bar, PIAA 520's, PIAA Headlamp Upgrade Turbo-back Exhaust, LOADED...
even goner-2002 4x2 7.3L Ex Limited
Tags
184k , 2004 , 73 , chum , diesel , engine , excursion , f350 , ford , mileage , miles , motor , psd , triton , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
