Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 11:51 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
Husqvarna Rancher 44
Picked one up the other day for $40, and it runs. Does this sound like a decent deal? Can I put a larger bar on it or am I stick with the 16"?
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #2 (permalink)
Old 06-28-2009, 01:48 AM
ford2go's Avatar
ford2go ford2go is offline
ford2go has a good reputation on FTE. ford2go has a good reputation on FTE. ford2go has a good reputation on FTE.
Usually can get a longer bar for pretty much anything. I don't know about Huskies -- except that they're supposed to be decent.
Do you need an 18? My first saw was an 18, but since then I've had 16s, and I have no complaints. They'll cut anything that I'm brave enough to tackle. (I've done double cuts in big stuff that's fallen. I may have done that to one or two that were upright, but my alz is pretty bad today, and I can't really remember).
__________________
ford2go (hj)
Wish I had -- F150 I6 5 speed
Have E350 RV
  #3 (permalink)
Old 06-28-2009, 02:37 PM
brownieboy525's Avatar
brownieboy525 brownieboy525 is offline
brownieboy525 is starting off with a positive reputation.
if it runs and cuts thats a good deal you got. you should be good with an 12-20" bar just keep the chain sharp
__________________
  • 1993 f-250 7.3L e4od 185,00 reg cab 3.55 rear end
Born to fish, forced to work!!!!
  #4 (permalink)
Old 06-28-2009, 09:57 PM
ckal704's Avatar
ckal704 ckal704 is offline
ckal704 has a great reputation on FTE. ckal704 has a great reputation on FTE. ckal704 has a great reputation on FTE. ckal704 has a great reputation on FTE.
I am not familiar with that model in particular, but if you look around on the web for husky parts you'll probably find that it is offered with bars up to at least 18 inches.
Get a husky part number and then you'll have a ton of options from aftermarket brands like Oregon, Great Bend, Windsor, etc.
And yes, keep the chain sharp!
__________________
97 250 PSD Ex Cab Sd 4X4 ZF5 135k
6637 in, 4" stainless ex
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
Marinco block heater tap
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
SiriusXM music & talk
Hula HP
EBPV brake
"I tried being reasonable. I didn't like it."
  #5 (permalink)
Old 07-29-2009, 02:44 PM
Ford_Six's Avatar
Does anyone know how to remove and replace the fuel line on this thing? It looks to have been hacked together at some point and is now leaking and causing it to stall.
__________________
Jared
FTE Guidelines
  #6 (permalink)
Old 08-02-2009, 11:51 PM
Ford_Six's Avatar
Ok, got that sorted out except I can't find a reputable dealer here. The local dealer sold me a coiled piece of hose for $7 that doesn't seal the fuel tank opening. He mentioned something about one with a grommet, but then said that wasn't for my saw. He probably should have said he didn't have one in stock.
__________________
Jared
FTE Guidelines
  #7 (permalink)
Old 09-28-2009, 10:28 PM
Ford_Six's Avatar
Well, since a search for "Husqvarna Rancher fuel line" on google turns up this thread, I'll post what I found:
The correct fuel line is part number 501458301, I got one off Ebay with a new filter for $18 shipped. Pricey, but it's right.
__________________
Jared
FTE Guidelines
  #8 (permalink)
Old 09-29-2009, 06:57 AM
ckal704's Avatar
Sounds fair enough, especially considering the purchase price of the saw.
A 44 probably costs $280-$310 new ( a guess). You are still way ahead of the game.
Happy sawing!
Cutting season is just around the corner, at least for me. I enjoy cutting wood for the next year in the cool of fall and early winter. Excellent outdoor activity!
__________________
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
Hula HP
EBPV brake
  #9 (permalink)
Old 10-01-2009, 07:02 PM
Eng1Driver's Avatar
Eng1Driver Eng1Driver is offline
Eng1Driver is starting off with a positive reputation.
I have a Husqvarna 45 chainsaw. I must say I really like Husqvarna chainsaw's. My saw won't get used for up to two years then start right up and work perfect. I always clean it good and run it out of gas before storage.
__________________
2008 Black F-350 Lariat CC SB: V10/T-Shift, ESOF 4X4, 4.30ls, Line-X, 18X9'' American Racing ATX Thugs, 325/60R18E Wrangler Silent Armor ProGrade, Bilstein HD Shocks.
  #10 (permalink)
Old 10-01-2009, 07:50 PM
iggybob44's Avatar
iggybob44 iggybob44 is offline
iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold iggybob44 is a splendid one to behold
Husky has two different bar mount platforms.........Up to about a 60cc saw(44 is a 44cc engine),is the smaller size,and mostly runs from 14" to 20" bar size....most huskies in that size run .325 pitch bar/chain combo....bar should be marked with .325 on it .......from about 61cc up to the the biggest 120cc models,a larger bar mount,and bars running from 16"- all the way up to 84" for the biggest models..........the Rancher 44 is an older model,all the newer models have 3 digit model numbers,mostly starting with the numbers 3 or 4.....as in 345 or 460.......check out the big mail order company Baileys for bars,chains,and replacement parts.........www.baileysonline.com........good service,good prices!
__________________
72 F250 C/S on 75 frame,390,np435,np205,warn8274
67-72? F250,360,np 435,dana 24.(likely a parts truck)
65 CJ5,225 V6,t90,18 w/warn O/D & ramsey PTO winch
80 Chevy K20,350,350,np205,ute bed,Ramsey RE10000
07 Dodge 2500,cummins 5.9,a/t,4x4 daily driver
09 load trail 16' 10K gvw car hauler trailer.
Tags
44 , bar , chain , decoder , ford , fuel , husky , husquvarna , husqvarna , line , long , parts , rancher , truck , trucks , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
