Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 10:31 AM
tommyleea tommyleea is offline
tommyleea is starting off with a positive reputation.
Update on one clunk
Previously posted about clunk when initially apply brakes. One time if going fwd, or one time if moving backward. Well, my anti rattle clip on the left front had broken in half, and therefore wasn't functioning as designed. Replaced the anti rattle clip and all WAS well. Went to change oil the other day, and was wiping things down. The front eye loop of both rear leaf springs was broken. The top half of the loop was just sitting there, on both sides! I could take my finger and move it back and forth. This BII has been driven gently, and the only time I use the 4WD is to keep it lubed up. I was astonished to say the least. This is just FYI for an area to inspect. New springs on the way thru LMC. Out
TommyJ
  #2 (permalink)
Old 06-28-2009, 03:22 AM
rebocardo rebocardo is offline
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
Wow, wonder how that happened. I have loaded my B2 with firewood right to the back of the front buckets until I thought the bumper was going to drag out of the woods and never broke a spring.
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
  #3 (permalink)
Old 07-03-2009, 10:39 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
These things are notorious for the springs going weak, especially if the leaf spring bolts get rusty and seize. Tommy, make sure you use plenty of anti-seize on the bolt shafts when you replace the springs. You may find you need all new bushings and bolts as well. I had to replace two of my bolts because the top shackle bolts were seized to the bushing inserts, which caused the bottom shackle/rear leaf bolts to wear abnormally and almost break. I still have to tear into it and replace all the bushings. I freed things up somewhat with liberal use of PB Blaster and WD-40, but couldn't get the top shackle bolts out when I replaced my springs, so I'll have to go back in again and replace bushings and bolts.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #4 (permalink)
Old 07-07-2009, 08:19 AM
Quote:
How right you are! Initially I was just going to replace the springs. Then I noticed that the rear shackle was frozen. I had to cut out the rear shackle on both sides. The springs and shackles came with new bushings, and I replaced the bolts also. All pretty and new now! Windshield is next. Cheers
TommyJ
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
