Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 10:15 AM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 is gaining momentum as a positive member of FTE.
Starting 4 projects today...pics (soon)
Well today is the big day...After a lot of saving and planning I am finally getting around to starting some projects I have been wanting to do on my truck. I figured that while I am sitting around trying to find a job I might as well do something useful.....and fun
This is what I was hoping to knock out in the next few days/week (or 2 lol)
1. I am going to pull the seats/carpet and put down herculiner on the floorboard of the truck (and maybe the rocker panels...it depends on how I feel after everything is back together)
2. While the seats are out I am going to install an 08 center console
3. Going to install a mount for my laptop in the cab
4. Going to install some drain holes in the floorboard of the truck. I am going to cut them the same size as the drain holes in the new Jeeps so I can use the Jeep floor plugs. That way I can just hose out my truck after mudding/playing etc.
(maybe #5) If I can find another 40/20/40 seat for cheap I might install that in the back of my CC along with another 08 center console so I can finally have the 4 capt chairs setup...but that all depends on the money
If yall have any tips or things I could do to complete any of these jobs faster please let me know.
I will be sure to post pictures throughout the "adventure"
__________________
Chris
M35A2 Deuce and-a-half
1996 F350 Crew-Cab 4x4 7.3 Powerstroke SRW
217K miles; 6in suspension lift; 33in BFG M/Ts; T3 "Get outta my way mod" w/warn 12K winch; WARN hubs; CB; Gauges; Herculined inside cab; 2008 Center console
  #2 (permalink)
Old 06-27-2009, 10:24 AM
Epd444's Avatar
Epd444 Epd444 is offline
Epd444 is starting off with a positive reputation.
Only tip I have is make sure you prep it good for the herculiner otherwise it will flake off in no time.
__________________
1997 F350 7.3 Reg Cab 4x4
64k E4OD 4.10LS
6'' Skyjacker on 38'' TSL's on Classic II's
3" downpipe to 5" Stacks
TW 6 pos chip, AFE stage 2 intake
FPR shim, 140 IDM, CCV, IC
  #3 (permalink)
Old 06-27-2009, 10:26 AM
Quote:
That is what I keep hearing from folks who have used it...I bought some sanding/scoring pads for my drill as well as some 60grit sandpaper.
I am going to take my time w/the prep...then do more just to make sure I do it correctly
__________________
Chris
  #4 (permalink)
Old 06-27-2009, 11:32 AM
Talyn's Avatar
Talyn Talyn is offline
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
Oh my, look what i started!
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Head over to www.midnightmods.com to see some of my projects.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
  #5 (permalink)
Old 06-27-2009, 01:04 PM
This is what has been completed so far and it was FILTHY under the seats.
I am calling it for now...it just reached 101 outside (w/heat index of 104 and still rising) and its pretty darn toasty. I am going to hold off until this evening when it begins to cool off a little.
I Link to my webshots w/all of todays pics
http://community.webshots.com/album/...host=community
__________________
Chris
  #6 (permalink)
Old 06-27-2009, 01:32 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
Looks good to me... how much do those '08 center consoles run? And where do you guys find them?
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #7 (permalink)
Old 06-27-2009, 01:35 PM
Quote:
I can only find then on Ebay for a normal price. I checked at the stealership and the parts guy said they dont have entire thing built and I had to order the parts individually and assemble it...which on ebay they are around 130-170 but if I had ordered each part from the stealership it would total over $300
__________________
Chris
  #8 (permalink)
Old 06-28-2009, 08:04 AM
Well this morning I woke up early before church and starting grinding w/the sanding attachment for my drill. I was able to knock out all of the major areas...I still have to go back in and finish up some smaller areas by hand. I have to get ready for church right now but I will post a pic afterwards.
__________________
Chris
  #9 (permalink)
Old 06-28-2009, 09:46 AM
This mornings progress....
__________________
Chris
  #10 (permalink)
Old 06-28-2009, 10:31 AM
Talyn's Avatar
1994 Ford F-250
Looks good.
Use some naptha or something similar to clean the surface before bonding the paint/liner.
__________________
  #11 (permalink)
Old 06-28-2009, 10:34 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is online now
Adrenaline Junky
Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE.
I wonder if the herculiner will be OK its applied on top of the sound deadener (rubber) stuck on the floor?
It may flake or peel off IMO.
__________________
JIM
  #12 (permalink)
Old 06-28-2009, 10:58 AM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
Looks good. I wish I had that much ambition in temperatures like that.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / DP-TUNER / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water/Oil Temp]
4" Straight / 6637 / CCV / 203 Stat
  #13 (permalink)
Old 06-28-2009, 10:59 AM
Talyn's Avatar
1994 Ford F-250
You can see in the pics of mine, that i pulled the deadener off cause it was already pealing off. they came off almost in one piece.
__________________
  #14 (permalink)
Old 06-28-2009, 11:00 AM
Talyn's Avatar
1994 Ford F-250
Oh, make sure you take those damn seat belt buckles out and put the bolt back in.
its a t50.
__________________
  #15 (permalink)
Old 06-28-2009, 11:03 AM
Quote:
Originally Posted by Talyn View Post
Looks good.
I picked up some acetone that I was going to use to prep/clean the surface
How does naptha rank compated to acetone/MEK/Xylene? I have never used it.
I was actually wondering the same thing, I had planned on taking the stuff off until I found out how much it was stuck onto the floor. My plan is to apply the liner over the rubber (I already roughed it up w/the grinder) and see how it works out. If it doesnt bond...that will be a project for another weekend.
__________________
Chris
Tags
cab , center , company , console , crew , decoder , deuce , fetters , ford , half , inside , lifted , m35a2 , motor , obs , pics , rich , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
