Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 09:20 AM
Argess Argess is offline
Argess is starting off with a positive reputation.
Rubber Fuel Line Story
A few years ago, I went to use my car for the first time in the spring and had some trouble (428, so I thought I'd post here....LOL). Over the winter, the short rubber fuel line between the metal fuel line along the frame and the fitting on the fuel pump had rotted away and small bits of rubber plugged up the fuel filter at the carb once I started the engine. Although the hose was only a few years old and should have clued me in to an issue, I merely replaced the hose, cleaned the filter, and more or less forgot about it.
Since then, I had a problem with the 50 gallon tank in my boat. Fuel fitting is on the top and connected to it is a piece of plastic tubing that goes almost to the bottom of the tank. I removed this and found the tube to be brittle and basically it fell apart in my hands. So I replaced it with a piece of rubber fuel line and added a brass fitting at the end to sort of act as a weight.
Two days later I checked the new hose and found it completely swelled up and very soft. The gas was attacking this piece of automotive fuel hose. How can this be?
As near as I can tell, rubber fuel line is processed somehow (vulcanizing?) on "the inside only", and therefore only the inside is gasoline proof. Ah Ha! Now I understand what happend to the short line feeding my 428. The sharp edge of the metal fuel line must have cut into the rubber fuel line a bit and everything went down hill from there.
So, the point of this story is to let people know they should trim all sharp edges of metal lines when connecting to rubber hose. Maybe even a partial double flare. Barbed fittings (like on the fuel pump) worry me too, but so far, they seem not to cut into the rubber like the sharp end of a metal fuel line. However as I am re-installing my engine, I think I'll put in a new piece of rubber fuel line just in case it got cut when I removed it taking the engine out.
Side-Note: For the boat, I finally used some sort of clear plastic tubing from the hardware store. I think it is some sort of PVC. It's been submerged in gas for a few years now and I've stopped checking it, as it's been fine every time I did check. Oh....I had to use flexible line as the tank is below the deck and the tube has to bend when you remove it.
  #2 (permalink)
Old 06-28-2009, 01:41 PM
fordinlinesix fordinlinesix is offline
fordinlinesix is starting off with a positive reputation.
Wow, I never thought about that, thanks for the tip! I'm sure the ethanol in gas doesn't help matters any better too.
  #3 (permalink)
Old 06-30-2009, 01:04 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Freightrain is gaining momentum as a positive member of FTE.
Rubber fuel lines...................ah yes.
Back in '01? Daily driver was '86 LTD II (V6) and one day it wouldn't start. After lots of messing around I pulled the tank and found the 2" long rubber line between pump and bracket that hold it inside tank had rotted away. Huh? Why put rubber INSIDE the tank? How about mounting the pump to a steel line with a Oring or such? Whatever.
My '69 F100 had issues one day, barely made it home before finally wheezing to a stop. No fuel. Traced it back to my fuel cell in the bed(18 gal race unit) which happen to have a RUBBER line inside for a pickup tube. Great, it had rotted apart after 15 yrs or so. I replaced it with a nice 1/2" alum line bent back to rear side of cell. Kinda pain to get in, but don't have to worry about it anymore. Plenty of foam to support the tube also, so it shouldn't break off. It uses a AN bulkhead fitting to get through body of tank.
__________________
*signature delete option*
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
