Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 09:02 AM
timothy47129's Avatar
timothy47129 timothy47129 is offline
timothy47129 is starting off with a positive reputation.
FE c6 with np205
Does anyone know anything about a c6 transmission that has the Fe bolt pattern and bolts to the np205 transfercase.Im looking into one for a 390 swap in my 78 with a np205.I have heard they are hard to find.
any info appreciated
thanks
__________________
I dont claim to know everything,But I did stay at a holiday inn express last night
There are always 3 ways to fix something
1:The expensive correct way
2:The cheap correct way and
3:The half a** way
  #2 (permalink)
Old 06-27-2009, 04:05 PM
mark a.'s Avatar
mark a. mark a. is online now
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
Your '78 would need the neutral/reverse switch on the trans. It would also need the right shifter to go with it. You would need the shifter with the slot cut in it to work the switch. The case would also have to have the two bolt hole provisions for the switch to bolt on. You will have to figure out if you need the short tail shaft or the long one. I believe the FE has a 3 bolt starter too.
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 06-27-2009, 11:57 PM
Well I got it today for $75.00.Its suppost to only have 10,000 miles on it.It has a Tci torque convertor that stalls 500rpm mopre than stock,And maybe a shift kit.The guy I got it from had it built about 7 years ago.Junked the truck and pulled it.It has been sitting 5 years in his garage.Thats why he wasnt sure about the shift kit.It looks clean and you can tell by the gaskets its been rebuilt.What are the chances its hurt it sitting for 5 years.I have always heard from tranny guys you need to turn them over by hand a few times a year when sitting.I am going to install a new front seal,fluid and filter for good measures.
Also it has the right switch mounted on it with the linkage.And it doesnt have a tailshaft it has an extention to bolt to my np205
Thanks
__________________
3:The half a** way
  #4 (permalink)
Old 06-28-2009, 11:11 AM
mark a.'s Avatar
There are 2 different tailshaft lengths that go with their matched housings for the 4x4's. They both use the same spline count though. I wouldn't worry about it sitting. If your putting it in where one went bad I'd flush the lines & cooler real good first.
__________________
  #5 (permalink)
Old 07-03-2009, 12:42 AM
I didnt know there were 2 different lengths.That should make my swap fun.
Tim
__________________
3:The half a** way
  #6 (permalink)
Old 07-03-2009, 10:24 AM
mark a.'s Avatar
If you have the C6 that came from your truck you can swap the tail shafts & housings if they are different. You have to tear the whole trans down to do it though.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
