Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 02:06 AM
Cruiseomatic's Avatar
Cruiseomatic Cruiseomatic is offline
Cruiseomatic is starting off with a positive reputation.
Burning oil at high RPMs
My '66 289 burns oil when I accelerate and rev it up. It is not bad but noticable. I don't have the time or money to pull the engine and replace parts,Will an oil additive work and if so what are some good ones? I see a lot of them but heard some are just snake oil. I'm tired of fouling plugs up and needing to replace them.
Thanks guys.
__________________
1989 F150 Custom-Straight 6 300 C.I. - C6 Tranny
2001 Chevy Silverado 1500 -Ext. Cab (4 Doors) 4.8L V8
1966 Mercury Comet Caliente 289 C.I. V8-C4 Tranny
  #2 (permalink)
Old 06-27-2009, 03:40 PM
guitarnik's Avatar
guitarnik guitarnik is offline
1990 Ford F-250
guitarnik is starting off with a positive reputation.
youve proly got bad rings would be my guess. i dont think any additives will fix this. but i would go look at them and see if some say that they seal worn rings.
__________________
90 f250 4x4 5-speed 351w headman LT's 33x12.5 coopers CHEVROLET-Cheap Hardly Efficient Virually Runs On Luck Every Time
  #3 (permalink)
Old 06-27-2009, 11:10 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
Is the pcv valve hooked up & working ? I'd check all the cylinder with a psi gage.
__________________
'79 F250 13" lift 42" Super Swampers
  #4 (permalink)
Old 06-28-2009, 03:10 AM
New PCV installed and connected to carb like in the instructions. It only does it on startup and hard acceleration. Buddy recommended lucas oil to see what it will do.
__________________
  #5 (permalink)
Old 06-29-2009, 07:27 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is online now
EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE.
If it's less than a quart every 1000 miles, I wouldn't worry about it.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
  #6 (permalink)
Old 06-29-2009, 09:20 PM
petes79f150 petes79f150 is offline
Social Outcast
petes79f150 is a name known to all petes79f150 is a name known to all petes79f150 is a name known to all petes79f150 is a name known to all petes79f150 is a name known to all petes79f150 is a name known to all
How many miles on engine? Could be rings, could be worn valve guides/seals. No. 4 cylinder(pass.rear) plug fouling the worst? Typical SBF.
Pete
__________________
The Hurrier I Go, The Behinder I Get.
  #7 (permalink)
Old 06-30-2009, 12:29 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Stock valve seals are neoprene umbrella type. They get hard and crack. They will cause smoke at start up, and especially when there is a high vacuum situation. High miles? To be expected.
  #8 (permalink)
Old 07-01-2009, 06:10 AM
Don't know how many miles are on it,Have'nt checked the plugs lately,Will do when I get it to Houston.
__________________
  #9 (permalink)
Old 07-01-2009, 06:16 AM
rsylvstr's Avatar
rsylvstr rsylvstr is offline
Flt Marine Force Corpsman
rsylvstr has a very good reputation on FTE. rsylvstr has a very good reputation on FTE. rsylvstr has a very good reputation on FTE.
doesn't hurt to try www.auto-rx.com
__________________
The best battlefield medicine is fire superiority
2001 SCrew Lariat 4x4 5.4L 4R70W 3.55 's LS
Cooper ATR's, K&N Series 77 CAI
Nasta S/S nerfs, Rancho RSX
http://home.rr.com/robandvic
  #10 (permalink)
Old 07-03-2009, 10:22 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
If it's the valve stem seals, you could probably change them out without tearing that far into the engine. I've seen 'special air fittings' that allow you to use the spark plug hole and air hose to keep the valves closed when you remove the springs and locks. I've also seen valve spring compressors that work well for doing it with the heads still on the block. There aren't any oil additives I know of that 'fix' bad rings or bad seals. One thing you may consider as far as the rings, though, is using a thicker grade oil. I take it the odometer has rolled over at least once... considering you don't know how many miles are on the car / engine?
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #11 (permalink)
Old 07-15-2009, 01:41 PM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
You can also try the 'rope trick' where you remove the plug, install feet of rope, leaving a bit to hang onto, and then rotate the crankshaft to push the rope against the valves. Then remove the keepers, the valve springs and the remaining chunks of your valve stem seals. They are likely in bits, lying at the bottom of the rocker arm cover and plugging the oil return holes at the back of the head. Install new seal, springs, and keeper. Remove rope. Rinse, and repeat 7X....
It can be done in about 3-4 hours or less. After you do the first one, the rest seem simple.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
Tags
2001 , 48l , burning , chevy , ford , location , oil , pcv , silverado , v8 , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
