Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-26-2009, 11:00 PM
jsalty jsalty is offline
jsalty is starting off with a positive reputation.
1970 302
Hello All,
I have a 1970 302 in my F100 (same year). She as a miss at idle and I was thinking about removing the points & condenser and installing a points removal kit. only thing is I don't have any idea what would be the most reliable kit to use. does any one have experience with points removal kits and if so what has worked best for you?
Thank you,
Jim
  #2 (permalink)
Old 06-27-2009, 11:38 AM
gearhed1971's Avatar
gearhed1971 gearhed1971 is offline
1973 Ford F-100
gearhed1971 is starting off with a positive reputation.
Install a Pertronix,its probably the best for the money.Very easy to put in,just goes in place of the points.
__________________
gearhed1971
1973 f100-390 4wd
1963 falcon-under construction
1951chebby special deluxe(for sale)-SOLD!!!
daily beater poontang sunfire
  #3 (permalink)
Old 06-27-2009, 11:53 AM
daveengelson's Avatar
daveengelson daveengelson is offline
daveengelson is gaining momentum as a positive member of FTE. daveengelson is gaining momentum as a positive member of FTE.
Understand the Pertronix is simplest route to go, there are several threads where members mentions they were pleased with the kits. Went with the Duraspark II in the 65 which has a 70 Torino 302, very pleased. Other than not having to deal with setting the point gap, with the Duraspark, the plug gap increased to .044, not sure about pertronix, may want to confirm if go that route.
__________________
'problem with engaging in useless activity is never knowing when your done'
Never engage in a battle of wits half armed!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
  #4 (permalink)
Old 06-27-2009, 12:05 PM
Thanks all, I will search again for some info.
  #5 (permalink)
Old 06-28-2009, 02:19 PM
Nathan Plemons Nathan Plemons is offline
1995 Ford F-150
My Garage
Nathan Plemons is starting off with a positive reputation.
I have recently asked this same question and was pointed towards the Pertronix kit. It seems to be the most proven solution. One gentleman told me to also get the Pertronix coil, he said he never had a problem with a kit so long as he used their coil too.
  #6 (permalink)
Old 06-28-2009, 09:20 PM
Thanks for the info.
I was looking at them just yesterday.. I also saw a ACCEL ignition one for $59.00 for the whole kit including the rotor. the only caution I have read is make sure you use a coil with less than 1 ohm resistance. the replacement module is only $30.00 for the accel also.
Don't know if anyone has any experience with the ACCEL but it's a heck of a lot cheaper than any other ones.
BTW-- when looking at pertronix what version is best not just based on highest priced being best. I beleive II would be good and III overboard for a mostly stock engine.
thanks all.
  #7 (permalink)
Old 06-28-2009, 11:42 PM
bmz's Avatar
bmz bmz is offline
bmz is starting off with a positive reputation.
Thumbs up "the flame thrower coil"
Be careful about the coil you use or you could fry you stuff you just installed
your better off getting the complete kit I went with the accel no problems at all
  #8 (permalink)
Old 06-28-2009, 11:50 PM
What coil did you use..I have not seen anything specific to the coil with the accel package. Just to use one with less than 1 ohm primary resistance ...
did not see any accel kits with a coil, yet.
  #9 (permalink)
Old 06-29-2009, 09:36 PM
bmz's Avatar
bmz bmz is offline
The "Flame Thrower"
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
