Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Computer Chips and Tuners SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-26-2009, 10:50 PM
IRUNUOVER IRUNUOVER is offline
IRUNUOVER is starting off with a positive reputation.
Edge Programer!!
Im lookin to put an edge programer on my 04 f250 6.0 diesel.. What are some of you guys opinions?
  #2 (permalink)
Old 06-26-2009, 11:44 PM
Oversize's Avatar
Oversize Oversize is offline
1996 Ford F-250
Oversize is gaining momentum as a positive member of FTE.
There are various threads on here about edge, Ive had them on 2 of them on 1 my trucks and its ok the other Ive tried 4 different edge chips and programmers and the edge stuff kept messing up the PCM thus needing to be reflashed or the physical chip to be removed to get it to run right after I installed there stuff. Their customer service is pretty bad. I had them all on a 7.3's of different years and dont know how they do with a 6.0 but I dont recommend them. Too much headache for too little gain. They are also known to be hard on trannys. Id recommend looking into a better brand more specifically get a custom chip they cost about the same and work better.
__________________
96 F-250 HD, SC, LB, 7.3 DI Diesel, 5 spd, 6" lift, 35" AT's, 3" DP, cat gut, 6" straight pipe, 4.10's, FPR shim, custom intake, Hot pedal, HPX, Pyro, Boost, ...
Professional driver, Former CAT and Industrial Mech, P/T race engineer.
  #3 (permalink)
Old 06-28-2009, 09:33 AM
What other brand would you recommend lookin into?
  #4 (permalink)
Old 06-28-2009, 11:19 PM
tex25025's Avatar
tex25025 tex25025 is online now
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
For a 6.0 you're either wanting to get an SCT or you are wanting to get the Spartan Phalanx, both offer custom tunes and starting with the 6.0 to current Ford trucks, you are going to want custom tunes on these trucks. Any of your standard programmers that you see in the magazines or see all the ads elsewhere for have a bad reputation and you're playing with fire and will eventually get burned if you use them on the 6.0.
7.3s can get away with a lot more then we can and I would highly discourage you from any of the standard tuners that you hear about and stay away from "shift-on-the-fly" those are the worst types for the 6.0.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #5 (permalink)
Old 06-30-2009, 12:44 AM
Okay thanks alot for the info!!
  #6 (permalink)
Old 06-30-2009, 10:57 PM
DSTRBD's Avatar
DSTRBD DSTRBD is offline
PREMIUM SPONSOR
DSTRBD is starting off with a positive reputation.
SCT is the way to go for the 6.0L. The canned tunes run great and if you are looking for more, custom tuning is available.
__________________
Performance Truck Products
888-516-4644
Got Questions? Chat LIVE on Our Site
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
