Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Aftermarket Products SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-26-2009, 08:08 PM
mchbts mchbts is offline
mchbts is starting off with a positive reputation.
POR 15 Question- Anyone used it?
Hey guys
Just wondering if anyone has used POR 15 and what there results/opinions were? I am thinking about using it some trouble rust areas on my 86 F150. The main areas are the door bottoms and front lip on the underside of the hood, but if it works well, I may splurge and paint the whole underneath of the truck with it. Any opinions let me know. And also can it be applied with a spray gun? And are the POR prep products really necessary is the area is cleaned up well? Thanks
  #2 (permalink)
Old 06-26-2009, 08:39 PM
Big_Al59 Big_Al59 is offline
Big_Al59 is starting off with a positive reputation.
I've used it on my winch bumpers that were painted black. It worked good for that, didn't use any of their other stuff. Just cleaned the dirt and crud off and excess rust then brushed it on. Been on there about 3 years and still looks ok, no return of rust.
  #3 (permalink)
Old 06-26-2009, 09:42 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is online now
2004 Ford F-250
1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE.
I used POR-15 on my Early Bronco frame and axles. This product is highly recommended in the EB world for doing frames and such. I used the prep products as suggested and it worked great. Not sure how "necessary" it is but I went for it.
You can spray it but I brushed mine on. It flows REAL nice to the point that you can't tell it was brushed on once it dries.
And... a little bit goes a long ways! I did my frame, front and rear axles, rear springs, radius arms, etc with one quart. That was two coats on everything.
The only other thing I can remember about it is that if it gets exposed to the sun it will fade badly. From what I read it doesn't break down and begin to fail, it just fades. I top coated my frame with chassis black from Eastwood. Here's a few pics.
  #4 (permalink)
Old 06-27-2009, 02:46 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
I used it on a 9" axle that sat on my back porch and a gas tank on one of my trucks. It is UV sensitive, so if its going to exposed at all, you need something on top of it. My gas tank peeled and flaked only in the places you could see, on top and front where it stayed in the dark held up fine. The axle is showing some rust through, but it's been 8 or 9 years since I por'd it and no top coat.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #5 (permalink)
Old 06-30-2009, 03:32 PM
Rewired Rewired is offline
Rewired is starting off with a positive reputation.
I've used it to treat surface rust. Haven't used it in a long while though. It works well, but we also don't have salted roads, or salt in the air here. I used it as more of a detterent.
  #6 (permalink)
Old 06-30-2009, 03:48 PM
bnovak bnovak is offline
bnovak is starting off with a positive reputation.
The stuff is fantastic. But, as was mentioned it doesn't work to well in a salty environment. If you have rust spots on the frame, use the POR on it, then hit it with a rubberized undercoating spray. I would do this on the underside of your doors if it isn't a visible area. For the hood, if it's visible, hit it with a good touch up paint and sealer and you should be good to go.
I DIDN'T use the prep products, and had no issues. Just the usual. Sand the old stuff down, etching primer, then the POR on top. I did the entire frame and underside of the tub of my willy's with it, and my parents used it on steel I-beams that hold up their concrete garage floor. But again, if it's salty enviro, you gotta seal it.
  #7 (permalink)
Old 08-09-2009, 10:34 PM
restorit's Avatar
restorit restorit is offline
restorit is starting off with a positive reputation.
I wire-wheeled the frame and underbody of my '85 Bronco in 1999, and also sanded the outside of the fuel tank, shocks, suspension, etc. I didn't use any of the POR-15 prep products, just the paint itself to cover. While the POR was still tacky, I fogged over it with Rust Oleum Rusty Metal Primer (red oxide). After it was dry, I top coated everything with Rust Oleum black and platinum enamel. Ten years later (and three winters on salty Minnesota roads) there is absolutely no rust-through - the surface coatings on the underbody still look as they did the first year. This said, I will offer a couple of words of caution: I also soaked the inside of the tailgate shell and inner quarter panel / inner wheel wells with it - both areas appeared to be rust free at the time. Within a year and a half both started to rust through from the inside out. I'm convinced that in areas where the sheet metal overlapped and was spot-welded together, and where there was probably a bit of rust in between, my soaking of the overlapped joints sealed everything up to a point where the rust and moisture took a path outward. This was just way too pronounced and in too short of a time for me to believe otherwise. On flat surfaces, like frames and floor pans, two thumbs up!! On overlapped joints, like where door skins wrap around the shells, be careful - reskin or replace. If you wire wheel the bottom of a door and soak the paint through from the inside and along the bottom, the rust will likely find its way through the backside of the panel, or however else it can.
  #8 (permalink)
Old 08-10-2009, 11:54 AM
daveengelson's Avatar
daveengelson daveengelson is offline
daveengelson is gaining momentum as a positive member of FTE. daveengelson is gaining momentum as a positive member of FTE.
IMO, rust will resurface at some point, some products hold it off longer than others but Por 15 seems to work better than majority of the other products. Used a wire wheel, pressure hosed, used the 'marine clean' to wash the chassis, rinsed, then used spray gun to apply 2-3 coats. Strongly suggest purchasing container of their solvent, it certainly comes in handy for clean up purposes, and if decide to apply with spray gun it can be used to dilute the mixture if necessary. Most importantly, the solvent is the only product I found that will remove it, when instructions advise to remove within min's or paint will remain until it wears off they mean it.
__________________
'problem with engaging in useless activity is never knowing when your done'
Never engage in a battle of wits half armed!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
  #9 (permalink)
Old 08-10-2009, 03:57 PM
97nukeford's Avatar
97nukeford 97nukeford is online now
Nebraska Chapter LDR
2006 Ford F-250
My Garage
97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of
I was planning on doing the same process on my 67 F100 frame. I'm going to sandblast it first, then paint. Did you puff-can your chassis black, or use a spray gun, and did you paint it right afer putting on the POR-15, or put it on later?
__________________
Pat W.
Nebraska Chapter Leader and Official #2 Slackmaster!
2006 F-250/ 1997 F-150/1967 F-100
1967 F-100 Project
GO HUSKERS!!
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
  #10 (permalink)
Old 08-10-2009, 05:04 PM
2004 Ford F-250
Quote:
I just bought the aerosol cans of chassis black from Eastwood. I think it took about 4 cans...? I waited until the POR-15 had cured which I'm not sure if that was the best choice or not. We'll see I guess!
One thing on the chassis black, it takes a LONG time to cure. I'm talking, like a week. Its basically dry in a day or so, but if you handle the parts alot you'll soon notice that they're still slightly tacky. I thought something was wrong but after doing some reading online I found several others that had that same experience.
Tell me more about your '67. My Dad has a '67 4x4 short bed with the I6 motor, 240 cid I think..? It needs a lot of work but I don't see many '67s around here.
  #11 (permalink)
Old 08-10-2009, 05:30 PM
97nukeford's Avatar
2006 Ford F-250
My Garage
Mine is a longbed 4x4, with the 300-6 and a four speed. Found it up near Dubois, Wyoming about 12 years ago. About 10 years ago, the tranny went south on me, and I parked it. I bought a 390 a few years back, and I'd like to find a way to incorporate a later model four or five speed and 2 speed transfer case. It has the usual rust in the fenders, and I just discovered the cab floor will probably have to be replaced also. The bed isn't too bad, needs some work on both back corners, took hit's on both sides of the rear bumper.
I'll keep that in mind about the Chassis black. Did you primer before it, or just spray it over the POR-15?
__________________
Pat W.
1967 F-100 Project
GO HUSKERS!!
  #12 (permalink)
Old 08-10-2009, 09:13 PM
2004 Ford F-250
Sounds like a fun project! I always liked that vintage Ford pickups.
Ok... back on topic I just sprayed it right over top of the POR-15. No primer or anything. Its been a few years ago now but it seems like I might have hit the POR-15 briefly with a scotchbrite pad and tack rag before spraying on it.
Tags
15 , floor , florida , ford , forum , frame , opinion , pan , pickups , por , por15 , por15com , spokane , spray , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
