Well, you're probably not going to want to hear this, but a 750 CFM is too much carb for a "largely stock" 460. In stock form, they're not high-revvers...they're built for bottom-end torque. A stock 460 doesn't have the compression AND the cam profile to be a high-revving engine. The factory-issue 600 CFM will be plenty enough for 99% of the 460s out there. Now if you get into internal engine mods, then the 750 might come into play.
Having said that, and if you still want to keep the 4160 on there...if your truck takes off well, then bogs, then takes off again, you'll want to look for a pump cam with a more aggressive profile...one that ramps up fast, then trails off slow. There are a variety of pump cams in a pack...you'll most likely have to experiment.
Now, if your truck bogs at the hit of the throttle, it's likely that you'll need a bigger accelerator pump...50cc vs 30cc. On some manifolds, it's possible that you'll need to run a small spacer between the intake manifold and the carb.
All said, I think you'll be happier with a 600 or 650 CFM carb...years ago I actually picked up .4 seconds in the quarter-mile by "downgrading" to a 600.
HTH,
Pat
__________________
'89 F-150 F14 4.9L (18.37 @ 73 MPH)
'91 Crown Vic P74 5.0L (18.09 @ 75 MPH)
'75 Gran Torino 7.5+L (14.04 @ 97 MPH)
Congressman Jack Murtha called me a racist and a redneck...jeez, tell me something I DON'T know!
