Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-26-2009, 01:38 PM
mantta's Avatar
mantta mantta is offline
mantta is starting off with a positive reputation.
Overhead Four Wheel Drive Console
On my cousins 1988 Bronco II the light on the switch for the frour wheel drive don't come on when it is in 4 wheel drive. I suspect there is a bulb in that console that is not working. How do you get this console loose from the overhead?
Thanks!
__________________
ENCS(SS), (SW), USN RET (E-8)
Keweenaw Bay, MI
U.S. Navy (Submarine Service) 60-80
1989 F-150 XLT, 5.0, AOD
1999 Lincoln Town Car Sig Series
1930 Model "A" Coupe
  #2 (permalink)
Old 07-03-2009, 10:30 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
I can't remember if you have to take the rest of the trim inside the windshield off to get to what holds it up there or not. A Haynes or Chilton's - or even the online repair guides at autozone.com should clarify things. Is the transfer case actually engaging? You may also want to check the wiring connection(s) at the transfer case to see if it's sending signal back to the module and console that it's in 4 hi and 4 low.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
