2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
07 Expedition rear rotor removal
Old 08-11-2009, 06:30 PM
65 Cobra's Avatar
65 Cobra
65 Cobra is offline
I need to change the rear brake pads on a 2007 Expedition and was going to turn the rotors also. It appears the rotor is held onto the axle by a large nut and not having done any brake jobs in several years, I've never run into a rear rotor that's bolted on. Can anyone tell me if this is the case and if so, what size socket do I need to get it off. Also, I was curious if there is anything else I need to know before I dive in. I heard it was a bitch to get off.
Old 08-13-2009, 11:04 PM
gddyup's Avatar
gddyup
gddyup is offline
That big nut you see is for the rear CV shaft. The 07 Expy doesnt' have a solid rear axle like the older ones. That big nut is what holds the CV shaft to the hub. The rotor should come off after you remove the caliper and the backing plate. Once the caliper and backing plate are removed, the rotor should either be loose and easily removed, or you may have to give the rotor hub-face a little talking to with a hammer. If it doesn't look loose, give the hub-face a little kiss with a hammer and it'll loosen up. Just don't hit the actual braking surface. A little rap on the flat area around the axle studs. And don't hit the studs either!
Old 08-14-2009, 07:54 AM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
I like to use a dead blow hammer, 3 lb works good. And if you miss. . .it isn't the end of the world everytime like a metal hammer.
Old 08-15-2009, 09:25 AM
65 Cobra's Avatar
65 Cobra
65 Cobra is offline
Thanks for the help guys. I thought it was probably just stuck on there by rust but didn't want to force it until I found out for sure. I'll just get "Big Red," my 60oz. dead blow rubber mallet and have a talk with it. I appreciate it.
77_150_460
01-25-2010 06:14 PM
bigun72
1997 - 2003 F150
13
07-16-2009 12:31 AM
LARIAT 85
05-12-2009 04:28 PM
rat49f6
04-04-2009 09:22 AM
thedaddycat
Oil & Lubrication
02-27-2008 06:12 AM
Quick Reply: 07 Expedition rear rotor removal
